H-9 com spark plug
this thread has 2 replies and has been viewed 1254 times
Old 09-13-2004, 11:24:48 PM
Default H-9 com spark plug
Hello, I belive I read some where the H-9com spark plug is uncommon? I have one, and it has Ford on it also...any iterest/value. Can they be used on small engines? (Is it worth haveing?)
Old 09-15-2004, 01:48:46 AM
Andrew Mackey
Default Re: H-9 com spark plug
Champion H-10 is the common one : the H series is a 14mm plug with a 1/2" reach. most small engines use the J series, which is a 3/8" reach plug. If you try to use the H series plug in an engine designed for a J, you may have an interferance problem with internal moving parts (for instance, do not use the H series plug in the 3 1/2 or 4 HP aluminum block Techempseh engines (valve in block engines) as the valves will impact the plug. You will bend the valves! The H-9 is a cooler running plug, than the 10 Andrew
Old 09-15-2004, 09:46:52 AM
NOS IHC spark plug - What does it fit? Chris Kirk Antique Gas Engine Discussion 3 08-21-2006 07:07:30 AM
Spark plug gap WheelSpinner Antique Gas Engine Discussion 3 05-23-2006 09:17:42 PM
Spark Plug Bob Fultz Antique Gas Engine Discussion 2 07-12-2005 09:17:02 PM
spark plug jody smith Antique Engine Archives 7 07-19-2001 01:53:14 PM
JD spark plug Allen Heilner Antique Engine Archives 0 05-13-2001 06:09:56 PM
