Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
maytag question
I started my Maytag twin last night and it was only running on the rear cyl. the spark to the front...
this thread has 4 replies and has been viewed 586 times
Old 09-17-2004, 06:50 AM
Brian Thomas
Default maytag question
I started my Maytag twin last night and it was only running on the rear cyl. the spark to the front cyl is weak .does anyone have any ideas ? Thanks Brian
Old 09-17-2004, 10:21 AM
Dan Baalman
Default Re: maytag question
Make sure the spark plug wire is clean on the end going in to the coil. The coil itself might be going bad, hope not the new ones are pricey.
Old 09-17-2004, 02:04 PM
Papa Maytag
Hi, Make sure is it clean behind the flywheel. Another trick was to clean the bushing end of where the back mounting plate mounts to the shaft end. Make sure its clean there. Make sure the points are clean as well and gapped to .020 The spark plugs originally were gapped to .037 I have found lowering the gap to possibly .020 helped alot as well. Spark plug wire connections to the mag are clean and not hanging loose. Hope these few pointers get ya in the right direction.
Old 09-18-2004, 03:08 AM
Brent Wegher
Inspect/switch plugs. Also, sometimes the crimped on brass/steel connector (at the spark plug end of the wire) is corroded at the inside. There is a shart point on the connector that penetrates the insulation. Better to run the center wire out and wrap around a clean area of the connector.
Old 09-18-2004, 08:26 PM
Kevin Weis
Brian, I've had this happen to me on a twin. A re-adjustment of the coil armature on the backing plate to specs may improve the spark. It work for me one day, and then the coil went dead. Almost like it burned itself out. The old twin coils are famous for this sort of thing. The surface of the armature is supposed to be at the outside edge of the rib. If its not exactly in the right position it does greatly affect spark intensity. Hope this helps, Kevin
Maytag Question Mike S Maytag Engine Collectibles 6 06-11-2007 01:08 AM
Maytag 82 Question Frank K Jr. Maytag Engine Collectibles 9 04-24-2005 02:04 AM
Maytag Question Billy Boone Maytag Engine Collectibles 0 09-07-2004 08:56 PM
Maytag oil can question Mac Leod Maytag Engine Collectibles 7 09-06-2004 10:45 PM
Maytag Question Tom G Antique Engine Archives 3 07-08-2003 08:27 AM
