Briggs Z or ZZ
Hello. I hope that you all can help me out. I would like to know what difference between the Briggs...
this thread has 4 replies and has been viewed 586 times
Old 09-29-2004, 02:11 AM
Stevie Mote
Default Briggs Z or ZZ
Hello. I hope that you all can help me out. I would like to know what difference between the Briggs & Stratton Model Z and the ZZ. I would like to know if the parts are interchangable. THANKS ALL!!
Old 09-29-2004, 03:18 PM
Ned L
Default Re: Briggs Z or ZZ
I'd like to know also as I have a Z or a ZZ, but the tag is long missing so I don't know. I've been told that the "Z" had sleeve main bearings & the "ZZ" had roller mains (don't know if this is true or not). - I've not had mine apart to look at the bearings
Old 09-30-2004, 01:24 AM
joefisher
Guys, most of the parts interchange. Both had ball bearing mains. The two major differances were that the ZZ had a stamped steel flywheel housing and head cover. This helped cooling of the head and allowed the second difference, higher compression, by smaller combustion chamber. This gave more power[1.3 HP] at same rpm. JOE
Old 09-30-2004, 07:45 AM
Neale Behm
I don't know all of the specifics of the model Z but I have 4 ZZ's one of which has the cast flywheel housing and "flow-through" cooled cylinder head. The serial number shows it to be a 1945 model.
Old 09-30-2004, 12:52 PM
meco3hp
Hello,
I too have seen "ZZ"s that have the cast flywheel housing. I'm not sure what the diffence is.
Thanks Richard Jensen
Briggs ID Help Horse Power at 511 Small Air Cooled Gasoline Engines 4 08-21-2007 10:47 PM
Briggs R/RC DSHEP Small Air Cooled Gasoline Engines 2 05-30-2007 07:53 PM
Help with ID of Briggs james catrett Small Air Cooled Gasoline Engines 8 05-29-2007 02:58 AM
Briggs ZZ Burt Lade Antique Engine Archives 9 05-04-2003 08:26 PM
WMB Briggs Pat Barrett Antique Engine Archives 4 04-22-2003 11:44 PM
