Lawrence Radial generator
Anyone have info on what this eengine was used for? It is vertical 5 cylinder radial,30 volts,tact...
this thread has 3 replies and has been viewed 1013 times
Old 10-09-2004, 11:21 PM
DICK GRAYBILL
Default Lawrence Radial generator
Anyone have info on what this eengine was used for? It is vertical 5 cylinder radial,30 volts,tact goes to 6000 rpm. It has twin mags,double spark plugs runs real smooth.Gen is on the top of unit. Thanks. Dick in central Pa.
Old 10-10-2004, 03:28 AM
listerdiesel
Default Re: Lawrence Radial generator
Is is Lawrence or Lawrance ??
Lawrance made APU's for aircraft in WWII, sounds possibly like one of their units.
Peter
Old 10-10-2004, 07:02 PM
Marv. Weber
They made v twins and radials that were used for auxilary power units in ww2 and later aircraft. These provided power to get a engine started so that it's generator would be used to start the rest of the engines. The radials have been converted to power some homebuilt aircraft. The radial is a real class high quality engine. You can also convert apu's to arc welders and they work well for that application.
Marv. Weber
Old 10-10-2004, 08:46 PM
DICK GRAYBILL
Thanks so much for the information . Its a friends engine, he had it to a show Sat. It was quite a crowd pleaser when running on back of his pickup truck. Dick in central Pa.
The Hart Parr 30-60 of the late Lawrence Woolf German George Antique Tractors - Old Iron Lugs, Cleats and Tracks 6 09-13-2007 09:03 PM
Cat Radial Diesel K D Redd Vintage Diesel Engines 1 09-03-2007 11:47 PM
Lawrence Woolf German George Antique Tractors - Old Iron Lugs, Cleats and Tracks 33 03-02-2007 04:17 AM
David Lawrence Andrew Mackey Kohler Generators 1 01-09-2006 08:43 PM
I.R. RADIAL COMPRESSOR RICK Antique Engine Archives 6 05-12-2003 12:04 PM
