Ford 8N starter
Where can I get a Ford Jubilee or 8N starter? I want to build an engine starter and that was what...
this thread has 4 replies and has been viewed 1280 times
Old 10-28-2004, 10:57 PM
Lou Quirch
Default Ford 8N starter
Where can I get a Ford Jubilee or 8N starter? I want to build an engine starter and that was what was suggested by a fellow Smokestacker. Thanks in advance, Lou
Old 10-28-2004, 11:00 PM
George Andreasen
Default Re: Ford starter
Any of the old Ford starters up into the 1940's should work. The shaft protrudes without an outboard bearing like the new ones, making it easy to mount some sort of friction wheel. I'd suggest one from a flathead truck engine..they were a little beefier.
Old 10-29-2004, 08:52 AM
KBeitz
Also look for golf-cart starters or boat engine starters... Most of them have the bearings on both sides of the armature ...
Old 10-29-2004, 12:28 PM
David M. Lyon
I think any Ford motor company vehicle built prior to 1964 would have the old type starter drive that engaged from the back side of the flywheel...Any automotive armature or starter rebuild shop should have a few of them still around.
David M.
Old 10-29-2004, 02:03 PM
Mike Bisbee
I have seen a starter/generator from a old garden tractor( like cub cadet,bolens,massey etc) used to start engines.good luck !
Help with a starter montess Generators & Motors General Discussion 13 06-21-2008 12:49 PM
Ford LT 80 Brickman Garden Tractors / Mowers / Scooters 0 09-29-2006 11:14 PM
Starter for DJC William Snyder Generators & Motors General Discussion 9 09-03-2006 02:35 AM
8N ford Marty Nelson Antique Engine Archives 1 03-18-2004 04:22 PM
J.D. G STARTER $80.00 randy buff Generators & Motors General Discussion 0 10-07-2003 11:35 PM
[IMG] code is Off
