Allis Chalmers mag question
I'm posting this for a friend. He has an Allis Chalmers B & C that both need work on the mags. He...
this thread has 3 replies and has been viewed 1064 times
Old 11-12-2004, 06:07 PM
Mike Monnier's Avatar
Question Allis Chalmers mag question
I'm posting this for a friend. He has an Allis Chalmers B & C that both need work on the mags. He said the B has a very faint spark and the C has nothing. He's replaced the condensers in both, and says the distributor cap and rotor both look good. He's thinking about tearing them apart and replacing the coils next. I know just enough about single cylinder magnetos to be dangerous, but I'm completely at a loss with tractor mags. I'm looking for suggestions to help him out. Thanks, Mike
Old 11-12-2004, 08:01 PM
Smoke Smoke is offline
Default
How about the points in the mag. Maybe they need a little cleaning. Just a suggestion.
Old 06-01-2009, 01:17 PM
John Wilkinson John Wilkinson is offline
Default Re: Allis Chalmers mag question
Really old man told me to fix a weak spark file the points a little bit then re-set the gap to specs and you'll get a long spark.
Old 06-02-2009, 12:56 PM
Dempster Dempster is offline
Clean or replace points new. Gap to .015 for Fairbanks Morse X or .020 for FM J which is the most common mag on AC tractors back then. Could be a Wico, Bosch or other too. The coils are bad about going out on the FM mags especially the later orange expoxy ones and even the news sometimes aren't much improvement may be better with another good used coil. There are snap rings in behind the bearing on rotor shaft on that FM mag behind the seal has to come out before taking everything apart but coil will come out without doing that. Some online manuals that may help. If these don't cover you mag message me and I may have the info you need.
http://www.worldpath.net/~thompson/a.../magtiming.htm
http://www.oldengine.org/members/die.../PetrolMag.htm
Allis Chalmers 20-35 Dan Mannen Antique Tractors - Old Iron Lugs, Cleats and Tracks 17 05-12-2007 01:37 AM
Allis Chalmers D -14 Paul Voss Antique Tractor Talk 0 07-05-2006 09:57 PM
allis chalmers 20-35 John McFarland Antique Tractor Talk 2 06-09-2006 10:32 PM
Allis Chalmers Drew Antique Engine Archives 1 06-16-2004 09:37 PM
Allis Chalmers I.B. Aaron Antique Engine Archives 3 02-24-2001 12:00 AM
[IMG] code is Off
