Have question on charging
I have a charging problem with a 1954 Moline BG. Over charging with wireing where its at, if switch...
this thread has 2 replies and has been viewed 867 times
Old 11-13-2004, 05:05 PM
Keith E. Keith E. is offline
Default Have question on charging
I have a charging problem with a 1954 Moline BG. Over charging with wireing where its at, if switch wires it wont charge at all. Have tried other boards with no advise. Help me out guys, snows commin and the tractor aint runnin.
Old 11-13-2004, 05:27 PM
Smoke Smoke is offline
Default
Does that thing have a voltage regulator, if so, might be bad.
Old 12-30-2004, 03:54 AM
CharlieBiler CharlieBiler is offline
Default Re: Have question on charging
I assume your BG Moline is a Delco 12 volt unit with a two unit regulator. Remove the field wire from the regulator and the charge should stop. If you ground the field wire, the generator should go to full output. If this is so, the regulator is bad. Just adjust the vibrating coil to get the correct voltage of 14.3 volts at half throttle. Don't touch the cutout coil. It is the one that is locked on when the unit is running and drops out when stopped.
If the generator is one of the leftover Prestolites, from the Avery days of this model, it will need battery power applied to make the generator go full out. Remember; Delco on a Moline is 'A' circuit and is grounded to make it charge. Prestolite is 'B' circuit and it needs battery power to make it charge. If you have more trouble, email me. Once on a world far far away, I ran a generator and starter shop. Now I work in a Television plant and work as a babysitter to newbie Engineers.
DJB 6.0KW DC Charging Circuit question? mav7771 Onan Generators 12 08-20-2006 07:43 PM
Battery Charging AndyG Trucks, Trailers and Hauling for Shows 10 09-25-2005 05:27 PM
charging RV mag Tom Winland Antique Engine Archives 2 08-12-2002 01:31 PM
mag charging Tom Winland Antique Engine Archives 12 06-24-2002 03:32 PM
Magnito Charging Ken White Antique Engine Archives 2 02-15-2002 10:13 PM
[IMG] code is Off
