Kohler K91.Hello, I would like to get some information on my Kohler K91 engine... it is stuck and in need of...this thread has 5 replies and has been viewed 1317 times
Hello, I would like to get some information on my Kohler K91 engine... it is stuck and in need of work. Is it a common engine? When was it made (Sn. 4292xx)? what is the HP?
If you have a complete one could you take a few pictures and post them it would be a great help! Thanks Mac Leod |
Thanks...That will help alot
Mac Leod |
I have a few questions about my kohler K91, Are the bolts that hold the muffler welded on? I was trying to remove the nuts that held the muffler on and the bolts twisted off about a 1/4 inch from the engine block? Any idea as to the age of my enine S/N 429215?
More questions soon Mac Leod |
Mac Leod, Dont beleve they are welded in orginaly, but Im sure they are rusted plenty tight! Most of the Kohlers had the exaust port tapped with a pipe thread so you can screw a muffler in. Sorry I cant tellyou about the age.
The K-91 (4 HP) does not have the exhaust port tapped like the larger engines. The mounting bolts are studs screwed into the block. I have had some success removing broken ones by mig welding a nut to the remainder of stud and turning out with a wrench. The heat from welding will usually loosen them up. Don't know about age, but the later K series were assembled in Mexico.
| KOHLER of KOHLER Electric Plant | rvaccaro2 | Kohler Generators | 0 | 09-02-2007 07:11 PM |
| Kohler 7.5 RMK - Help! | Mark Briggs | Kohler Generators | 3 | 12-22-2006 02:28 AM |
| old old kohler | vanwest | Kohler Generators | 1 | 08-09-2006 11:01 AM |
| Kohler value? | Dewey | Kohler Generators | 31 | 08-17-2005 12:57 PM |
| Kohler 2 cyl.gen,set. | Arthur | Kohler Generators | 1 | 07-21-2005 11:27 PM |
