| Antique Engine Archives All archived posts from 1999 to 2004 when SmokStak was on EnginAds. This is a read-only board. |
Pitted cylender wallIs there a product to repair pits in the tail section of the cylinder wall. It appears to be water...this thread has 3 replies and has been viewed 2717 times
Is there a product to repair pits in the tail section of the cylinder wall. It appears to be water damage
The front 2/3s of the cylinder is in great shape. The engine runs great, doesn't seem to affect compression. Was thinking of J.B. weld and following up with a cylinder hone to true it up. Any suggestions?mike |
JB weld will work.
Make sure that the surface is VERY clean, and hane after it's cured. Oh be sure that it is not in the way of the piston rings! |
Let it be when the engine runs great, it doesn't harm the engine any further or you want to run it at max speed and power. JB-Weld will work, but you have to clean it very well. Excess can be removed by use of a piston ring.
I agree with John if its not broke dont fix it! Plus the pits hold some oil and help lubricate the cylinder.BobRR
| Pitted con. rod-use or don't use? | Edwin | Antique Gas Engine Discussion | 4 | 02-24-2008 02:52 PM |
| ported cylender?? | BobM | Oil Field Engines | 1 | 11-27-2006 10:28 PM |
| pitted cylynders | Bear | Antique Gas Engine Discussion | 6 | 01-26-2005 09:28 PM |
| Pitted Metal (How to Fix) | Brian | Paint Shop | 1 | 06-08-2003 07:01 PM |
| 3hp pitted | Dennis Strayer | Antique Engine Archives | 0 | 01-13-2002 09:49 AM |
