Paint Shop
novo or what?
i have this up-right motor that is about a three h.p.,it looks like a novo and i thought it was a...
this thread has 4 replies and has been viewed 1792 times
Old 12-17-2004, 02:44 PM
Wayne Knibbs Wayne Knibbs is offline
Default novo or what?
i have this up-right motor that is about a three h.p.,it looks like a novo and i thought it was a novo,untill i talked to Ed; at Hit-Miss,he said if it is a novo all the part numbers start with a S,these part numbers on this eng. start with J4 or J40.The original color is an Ox-vlood red,also the top of the cooling tank is removeable,This is so you can remove the two bull-plugs in side the tank,so you can remove the intake and exhaust valves;this motor dont have valve cages that you remove so you can get at the valves.It has the ser. number stamped on the bottom of the cooling tank,it is also stamped on the end of the crank shaft.the ser. number is C8355.There is no name plate or eny other markings.I am in the process of restoreing this eng. now,and would sure like to know what it is.---the bore&stoke is 4 1/4 -5 1/2.
Old 01-15-2005, 05:35 PM
Ackman's Avatar
Ackman Ackman is offline
Images: 22
Photo Re: novo or what?
Does the engine have a flyball govenor? Can you post a pic or E-mail a pic to me? You might have a 3-1/2 hp NORTHWESTERN, built by Northwestern Steel & Iron Works, Eau Claire, WI. They look somewhat like a NOVO & are often mistaken for them.
Old 01-18-2005, 03:40 PM
Default Re: novo or what?
Wayne,
I've been trying to email you and send you a picture but keep getting an error message when I hit the send button. Not sure if the problem is at my end but other emails are working. Can you send me your email address so I can try again?
Thanks,
Bill
Old 02-16-2005, 03:47 PM
Thanks for the help Randy,but after looking at your picture,it has a differant base than the Western,and i have scine found out it is very likely an IDEAL,made by Gould,Shapley and Muir,in Canada Thank You WAYNE.
Old 02-16-2005, 04:07 PM
BILL SHERLOCK I recieved the pictures you sent in the mail Bill,and was very happy to get them, after loking at the photo,s the engine is no dought the same as mine,in every detail; I am sorry about the mix up on our e-mail adress,some how you got an number 3 in the center of it,the right e-mail is weknibbs@sasktel.net;hope this works OK for you.I will get in touch with you in a couple of weeks Bye for now ,THANK YOU.
novo help tim rostar Antique Engine Archives 6 05-03-2004 06:48 PM
novo 1.5 rod tim rostar Antique Engine Archives 0 04-22-2004 06:55 PM
1hp Novo Preston Wells Antique Engine Archives 3 03-23-2004 02:01 PM
Novo AG (or 2V) ned Lloyd Antique Engine Archives 0 06-26-2002 08:46 AM
NOVO 6HP SAM Antique Engine Archives 2 12-08-2001 10:36 PM
