Briggs 23?????I bought a Briggs model 23 over the weekend I was thinking I needed a 23 when I actually needed a...this thread has 6 replies and has been viewed 745 times
I bought a Briggs model 23 over the weekend I was thinking I needed a 23 when I actually needed a 19, does anyone know the horsepower of the Model 23?? and will it bolt in place of a 19???
Briggs Model 23 is 8HP and should have same mounting holes
Ok Thanks I was told it was a same as a 23D and it wouldn't bolt so I figured I would ask for a second opinion....
The 19 has the same bore as the 23 but a shorter stroke. You may have a problem using the 23 if height is an issue...it's a couple inches taller.
If you are in the KY/OH area and need a 19 I can help...sorry I won't ship though. |
I always thought the 19 was 7 hp and the 14 was 5 hp, while the 23 was rated at 9 hp. Is this true? Thanks
-Nick |
Oh, also if you can get me the serial, type, and model #'s of both motors I will look to see if they have the same base casting P/N.
Well it looks like the engine mounting is different then the 19 was, Whats a 23 worth I might just sell it....
| Briggs ID Help | Horse Power at 511 | Small Air Cooled Gasoline Engines | 4 | 08-21-2007 10:47 PM |
| Briggs R/RC | DSHEP | Small Air Cooled Gasoline Engines | 2 | 05-30-2007 07:53 PM |
| Help with ID of Briggs | james catrett | Small Air Cooled Gasoline Engines | 8 | 05-29-2007 02:58 AM |
| Briggs ZZ | Burt Lade | Antique Engine Archives | 9 | 05-04-2003 08:26 PM |
| WMB Briggs | Pat Barrett | Antique Engine Archives | 4 | 04-22-2003 11:44 PM |
