Briggs & Stratton model Z infoCan any of you Briggs experts out there advise what size the threads are on the screw that forms...this thread has 4 replies and has been viewed 1189 times
Can any of you Briggs experts out there advise what size the threads are on the screw that forms the contact for the point set (part #291408) on a model Z?
Hopefully I've included a scan for the magneto assembly for a model ZZ which shows the points assembly which should be the same as a model Z. This is for a young engine restorer who is looking for a tap to thread his engine for the point screw. Thanks, Bill |
I have been emailing Sky about his screw for a couple days now trying to determine what size it is. I guess i should have asked where it was used first.
I have the Big Red Briggs Book. The scew Bill refers to #291408 is the screw that sandwiches and holds the point set- contact assembly together. the other screw that has the other half of the contact is #63238 for the model Z engine. Unfurtunatly they do not give the size in the book. Still researching.
I Get My Corn From A Jar
If I understand the question, the points have the flat bar and the other half of the points to make the contact. The ones that I have are 40 threads by 1/8". I am no expert by no means. Just wanted to help you. Thanks Harry! John
The Question is, is it a #6-40 american fine or a #5-44? Sky measures 11 threads in 1/4" which makes it a 44. He took it to a shop and they said it was 4MM by .60 which i can not find in the book,only 4mm by .75. The 4 mm is a lot closer to what John says it is. 1/8-40. I talked to an old engine guy and he says it is possible that briggs used a nonstandard thread so guys don't but regular machine scres in it for a set of contacts. But he is not positive about that. The delema goes on.
I just measured a #6-32 machine screw with my micrometer and came up with .1325" which is slightly larger than 1/8" (.125), so perhaps it's a #5? Don't think any of those old engines used metric sizes other than for spark plug threads in some cases??
Bill |
| Briggs and Stratton model 5? | Scott Wenrich | Small Air Cooled Gasoline Engines | 21 | 04-28-2008 09:48 PM |
| The Briggs and Stratton Model Y | Horse Power at 511 | Small Air Cooled Gasoline Engines | 4 | 11-14-2007 10:54 AM |
| Briggs and Stratton model AP | jakewells | Small Air Cooled Gasoline Engines | 7 | 10-18-2007 01:37 PM |
| Briggs & Stratton model ZZ | jerryows | Small Air Cooled Gasoline Engines | 2 | 02-07-2006 11:43 PM |
| Briggs and Stratton Model A | Pollack Pete | Antique Engine Archives | 4 | 09-15-2003 12:32 AM |
