Farmal tractors - wide front
Does anyone know if IH made the Farmal B with a wide front.I'm thinking about looking for a small...
this thread has 6 replies and has been viewed 2031 times
Old 12-24-2004, 03:36 PM
Mark Birdeau's Avatar
Mark Birdeau Mark Birdeau is offline
Default Farmal tractors - wide front
Does anyone know if IH made the Farmal B with a wide front.I'm thinking about looking for a small Farmal to pull a IH wagon with several IH and McCormick engines mounted on it.I thought an A,B,C,or Cub but I want a wide front. Thanks Mark:
Old 12-24-2004, 09:48 PM
HBurk HBurk is offline
Default Re: Farmal tractors
i am working on a 1940 farmall b, now. i may be wrong, but i don't think you will find a factory wide front farmall b. there was one on ebay several months back, but the guy finnally admitted that it was homemade.
Old 12-24-2004, 09:57 PM
Mike in NC's Avatar
Images: 62
I have never seen a model B with a wide front.
Old 12-28-2004, 09:50 PM
Nebraska Cowman's Avatar
Nebraska Cowman Nebraska Cowman is offline
You can put a wide front from an A on a B.
Old 01-25-2005, 11:52 AM
Jake Lessen's Avatar
Jake Lessen Jake Lessen is offline
Default Re: Farmal tractors - wide front
The Farmall A and B both had what the call "Cultivision", where the engine was offset to the left and the controls were offset to the right for better view of a belly mounted mower or row cultivator. The A was the wide front version, and the B had a narrow front. I suppose you could modify a B to have a wide front end, but from the factory, they were the narrow type.
Old 01-26-2005, 08:54 AM
Steve Wright's Avatar
Steve Wright Steve Wright is offline
Images: 2
The "B" was the two row version of the "A". Same motor etc. The left rear axle housing was long to cover the second row. Narrow front to go between the rows. There are far more "A's" out there than "B's". An "A" front end would not be wide enough without modifying it. If you have a "B" to work with I would keep it original. You would have a lot more lookers like me that drove one when I was a little kid. Never been that little since except in mind sometimes.
Steve in Nebraska
Old 01-27-2005, 09:11 PM
Rusty Seeker's Avatar
Rusty Seeker Rusty Seeker is offline
Email Not Working
I have a B, BN and a Super A (I'd know). A's have wide fronts and B's have narrow fronts. It would be too much of a hastle (but it is possible) to switch a B front with an A front for me to try. I dont think any farmer back in the day would even hastle with it either. A's have the left drop housing sucked right up to the differential, and the B's have long axel housings on both sides. If it is an A, the serial # tag should say FAA or FAAV (for an AV) then followed by a 3, 4, 5, or a 6 number digit. If it is a super, it should have a hydraulic rig set up on it, and a water pump. Hope this helps!
Rusty
John Deere 730 Wide Front on Steel??? Jeff Wahl Antique Tractor Talk 17 04-01-2008 01:42 PM
50 John Deere Wide-front Mike Harmeling Antique Tractor Talk 0 11-17-2007 05:14 PM
How to cross a wide river John Davidson Stationary Steam & Traction Engines 42 03-02-2007 12:30 PM
Farmal blue paint Mark Birdeau Antique Tractor Talk 13 06-07-2006 12:46 PM
Farmall Wide Front rwhite55 Antique Tractor Talk 0 04-06-2005 07:03 PM
[IMG] code is Off
