Mag. help (Bosch)This little fairbanks Z # 396180 came with an american Bosch AB33 LD-1 mounted on it. Can it be...this thread has 5 replies and has been viewed 957 times
This little fairbanks Z # 396180 came with an american Bosch AB33 LD-1 mounted on it. Can it be made to work? It has no spark now. I was told the AB33 would not work on a spark plug
Any help to clear this up for me?
Roger the AB33 is the correct mag for the early throttle governed Fairbanks Morse 1 1/2 hp Z engine. I restored one just like yours about 20 years ago and I still have the original AB34 that came off of that engine. the 33 and 34 are pretty much identical. I was told that the wire in them is very fine and that they are hard to rewind. I recomend that you find a good mag man to work on it unless you have some experience with mags.
My advise is always free and free advise is worth what you pay for it. Dick |
I have a Z 1-1/2 HP WITH an AB33 mag. It is a high tension mag and does fire the the spark plug. Who ever told you that, does not know what they are talking about. Try cleaning the points. This may solve your problem. Hope this is of help, Jim |
I agree with you. the AB33 was a good mag as far as I have found. I have found the most problems with them is the cleaning of the points. After that, they work fine. Jim |
The AB33 uses pretty much the same armature that ALL the Robert Bosch mags use which carry the coil AND condensor in the armature. If points setting doesn't do the trick it's most likely the coil although on rare occassions it's the condensor. When they're hot they're hot---when they're not they're expensive........................
![]() Don't overlook the magnets!!! I have found them to be PIGS to juice 'em up again but it CAN make the difference. Last edited by Craig A; 01-02-2005 at 10:07 PM. Reason: addiiton |
| Bosch Mag help | Rick Keane | Magnetos, Ignition Coils and Spark Plugs | 0 | 10-10-2006 09:29 PM |
| 1 1/2hp Int. M Bosch Mag | Rex Pyles | Antique Gas Engine Discussion | 1 | 02-10-2005 08:26 AM |
| Bosch Mag | Jason Dahm | Antique Engine Archives | 0 | 09-22-2003 12:11 AM |
| Bosch Mag | Doug Hamilton | Antique Engine Archives | 0 | 06-13-2003 09:24 AM |
| Bosch mag | Terry Taylor | Antique Engine Archives | 0 | 12-23-2001 12:55 PM |
