Ford Ferguson with ditch witch
There is an auction this weekend with an old Ford Ferguson tractor ( 1950's) and its has a large...
this thread has 2 replies and has been viewed 970 times
Old 01-07-2005, 10:39 PM
Scott's Avatar
Scott Scott is offline
Default Ford Ferguson with ditch witch
There is an auction this weekend with an old Ford Ferguson tractor ( 1950's) and its has a large 10' long ditch witch attached to it. It also has a wide front end on it with wheel weights and additonal weights hanging on the extended axle. The front wheels are as wide as the rear with the rims spun all the way out. Was this a factory made piece? I'll try and take a picture of it this weekend.
Old 01-07-2005, 11:03 PM
Mac Leod Mac Leod is offline
Default Re: Ford Ferguson with ditch witch
F, do not know much about that ditch witch...thought you might ind my search for information funny. anyways shopuld you like more info on the machine the charles machine co. is still producing them, do an introweb search and e mail them, most helpful people!
http://www.smokstak.com/forum/showthread.php?t=11887
Old 01-09-2005, 10:36 AM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
I'm a little confused as to what you are wanting to know is a factory piece. Are you trying to figure out if the Ditch Witch is a factory implement (no), or if the wheels are done right (yes). The front axles on the Ford N-series tractors were adjustable in and out to match the row width settings of the rear wheels. Rear wheels were adjustable from 48 to 72" in 2" increments. Fronts only had about 6 adjustments but still worked. The tractors could be set up for 1 or 2 row operation. Most people just use a single row setup.
http://img.photobucket.com/albums/v4...Picture078.jpg
Massey Ferguson 65 questions? Jordan Antique Tractor Talk 11 08-07-2009 08:02 AM
Ferguson hydraulic question Mike Monnier Antique Tractor Talk 2 02-29-2008 01:10 AM
Massey Ferguson 10 Tractor Frank Y Garden Tractors / Mowers / Scooters 4 02-08-2007 10:09 PM
Ferguson TO-35 ---I need advice Doug Reachard Antique Tractor Talk 1 02-28-2006 02:10 AM
water witch roger kirschenman Antique Engine Archives 1 04-30-2004 09:02 PM
[IMG] code is Off
