Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engine Collectibles
Maytag oil ratio
I am wondering what the best 2 cycle mix to you with a maytag Model 11 similar to a Model 92, I...
this thread has 4 replies and has been viewed 1075 times
Old 01-11-2005, 03:11 PM
Jonathan Widelo's Avatar
Question Maytag Question
I am wondering what the best 2 cycle mix to you with a maytag Model 11 similar to a Model 92, I just put new rings in one and want to make sure i dont carbon them up too bad, I know the mixtue is 16:1 or should i run it at a higher mixture to insure good lubrication to the rings ?
~ Jonathan
Old 01-11-2005, 05:32 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
Default Re: Maytag Question
I use about a 24:1 mix with regular chainsaw/lawnmower 2-stroke oil in mine. The spark plug looks okay, i still get the characteristic blue maytag smoke and I see a small amount of oil coming out of the exhaust pipe so I know things are getting lubed. Personally, i'm staying with what works best for me. Also, don't forget to add some Sta-bil to your gas as it takes FOREVER for these things to go through a tank!
Old 01-11-2005, 06:19 PM
Papa Maytag's Avatar
Papa Maytag Papa Maytag is offline
Maytag recomended a 16:1 mixture. I use straight SAE30 Non Detergent oil for mine.
Never fouled a plug at all. And it is plenty of lubrication for sure. There is always many opinions on this subject. And like in the above reply make sure you add Sta-Bil to the gas as well.
Old 01-12-2005, 09:35 PM
Kevin Weis Kevin Weis is offline
I used the non-detergent oil mixture last year at a show in a 92 on a washer. It did seem to foul the plug more than the modern standard 2 cycle mix even at a 24:1 mix. Also if any oil spray from the non-detergent gets on the engine it is twice the work to clean it off. Also I'm told that non-detergent oil will seperate in the tank if it sits for any length of time. This is also mentioned in an manual for an Assoicated Pony that I have. So in short I stick with the modern stuff as I have had no problems with it. My 2 cents worth. Kevin
Old 01-13-2005, 04:51 PM
Arlie Levy Arlie Levy is offline
I have been using regular lawnboy oil mixed at 32-1. It seems to still smoke and runs oil oil out the exhaust. Arlie
Typical Compression Ratio for Hit Miss Engine? DerekC Antique Gas Engine Discussion 14 11-08-2007 02:35 PM
Pulley Ratio / Ice Cream / RPM? bjaspud Maytag Engine Collectibles 5 06-16-2007 07:44 PM
Partner 1616 chainsaw fuel mix ratio??? Leland Chain Saw Collectors 3 03-06-2007 06:04 PM
Just curious about compression ratio WheelSpinner Antique Gas Engine Discussion 26 06-10-2006 10:22 PM
variable ratio belt transmissions GuyW Garden Tractors / Mowers / Scooters 1 11-03-2005 06:11 AM
