Running on LP
this thread has 3 replies and has been viewed 1680 times
Closed Thread
Old 01-14-2005, 10:20:20 PM
Justin Justin is offline
Default Running on LP
I have a FB zd that I am trying to run on lp. The carb was broke so I cut it off flat and JB welded a 3/8 lp fitting in it. I also took out the butterfly valve since the governer weights are broke, and jb welded up those holes. Now the problem is I can't get it to run. It will fire usually 2 or 3 time and quit. I can crank it over again and it will do the same thing every time. The gasket between the carb and block has a small leak could this be my problem?? No gas appears to leak out when running with a small amout of gas comming out, but it will leak if I turn the gas up to high. I have a high pressure regulator(21.8 psi) with a shut off valve after it to control the flow. I have used a low pressure secundary regulator and had the same problem. Any ideas??
Justin
Old 01-14-2005, 11:00:44 PM
hit-n-miss166922 hit-n-miss166922 is offline
Default Re: Running on LP
Hello from Wisconsin!!!
My opinions!!!! You should have a secondary regulator to drop the gas pressure to about 11 to 14 inches water collom, what a common gas grill regulator does. Also an on demand regulator. This works like a needle and float in a gasoline carb, shutting off the fuel flow when not needed. I think that you have so much gas that you are in effect flooding the engine. Thats why it starts, fires once or twice then stops. Hope this helps.
Old 01-14-2005, 11:57:16 PM
onlineyes onlineyes is offline
check here. this guy is great http://www.propanecarbs.com/
Old 01-15-2005, 12:41:17 AM
Images: 311
Also check this thread:
http://www.smokstak.com/forum/showth...hlight=propane
Closed Thread
The IHC M is running! Donald A Smith Antique Gas Engine Discussion 13 11-27-2007 09:18:29 PM
Got it running.......... Rich Martz Antique Gas Engine Discussion 4 11-04-2007 10:23:11 PM
Hot Running IHC 3 HP M Tom Graves Antique Engine Archives 8 03-30-2004 10:35:00 PM
6 HP Associated - Got it running! Paul Martin Antique Engine Archives 7 07-23-2003 02:59:41 PM
Running vs. non-running engines Chris Kirk Antique Engine Archives 19 12-22-2002 08:02:12 AM
