Valve lapping tool info neededDidn't know if this should be on small engines or smoke stak, but here goes. The Briggs small...this thread has 10 replies and has been viewed 1681 times
Didn't know if this should be on small engines or smoke stak, but here goes. The Briggs small engines have two pin holes in the valve tops. The suction cups do not like to work good when lapping valves on these, cup too big. I feel like there is a tool that fits the pin holes and has a shaft center for turning. Does anyone have one of these or know where to get one? Otherwise, I'll try to make one.
Pat~
I have one packed up some where. It resembles a brace bit drill and the tip has a small flat piece on the end of a rod with two tips that fit into those holes in the valve. As you crank, it alternates direction twisting back & forth with each twist overlapping the last to grind the valve in. I would say the one I have has to be 75 years old and works great. Last edited by Keith Smigle; 01-24-2005 at 09:25 PM. |
seen this in a old audels manual on engines.won't cost you anything .what you do is get a old broom stick handle or wooden dow pin.drive 2 nails the space you need then cut off the heads to fit yours valves .poor mans valve grinding stick-chuck
I use a screw driver lol
craig,i wish i had time to post many old time tip's .the old timers were pretty sharp on how to fix thing's on the spot and at little or no cost.if you can find the old audels books my favorite is the 1932 silver anry.issue. they all are great.they tell how to fix magnetos.repair cracked blocks using rust joints,how to fix hit/miss engines,delco lite plants,motorcycles.airplanes.if it's a engine they can tell you how to fix it.you can find these books sometimes at and old public libairy.the one in cinti,ohio has it all in old books -chuck
I just use a piece of rubber gas line hose slid over the end of the valve stem.
Thanks guys, I'm going to use the broom handle and nails, sounds easy, just take some dividers, index in the holes, and transfer to the end of broom handle and tap in nails and grind off heads. Don't know why I couldn't think of something that simple.
pat,don't waste your time grinding the nail heads off.just cut the heads off using a side cutter,if it,s off a little bend the nails in or out to fit.-chuck
| Valve guide knurling tool | chipflyer | Machine Shop and Tool Talk | 12 | 10-02-2008 08:44 PM |
| Need info on this tool | oldtool53 | Machine Shop and Tool Talk | 1 | 03-25-2007 09:48 PM |
| lapping | DanR | Antique Gas Engine Discussion | 1 | 01-16-2006 09:55 AM |
| Tool ID Needed | Smoke | Antique Gas Engine Discussion | 4 | 02-06-2005 05:57 AM |
| Valve lapping problem | NICK | Antique Engine Archives | 3 | 11-13-2000 06:20 PM |
