pitted cylynders
this thread has 6 replies and has been viewed 2585 times
Old 01-25-2005, 09:07:02 AM
Bear Bear is offline
Default pitted cylynders
i got in on a partial conversation at a show about fixing rust pits in cylynders with some type of high heat epoxy. has anyone ever done this. if there is i've got one i may try it on. there is 3 rust pits on the bottom of the cylynder big enough i think oil slobber would be a problem but not big enough to bore and dry sleeve in my opinion. any ideas?
Old 01-25-2005, 10:21:11 AM
ssimntih's Avatar
ssimntih ssimntih is offline
Images: 59
Default Re: pitted cylynders
The only thing that comes to mind is thermal spray. I'm not exactly sure how it works, as I've never seen it done, but I think it works kinda like powder coating, only, of course, the powder is an alloy of some sort. A good machine shop here doesn't even weld cast anymore, he said they thermal spray it all. Might be worth looking into...
Old 01-25-2005, 11:17:25 AM
Elden DuRand's Avatar
Images: 6
Bear:
If, as you say, the pits are out of the area of ring travel, I'd just leave it as is.
If you feel that you must fix the pits, get them REALLY clean and use something like "JB Weld", iron filled Belzona or iron filled Devcon.
Fill the pits then, after the epoxy has thoroughly hardened, lightly hone the surface to match the bore.
Good luck - Elden
Old 01-25-2005, 06:21:21 PM
Al Wait Al Wait is offline
Use the regular J-B Weld, not the "quickie" 4-minute stuff. The area must be chemically CLEAN!!!!!!!! Al Wait
Old 01-25-2005, 08:24:50 PM
Rob Skinner's Avatar
Rob Skinner Rob Skinner is offline
Yep, I've done it using Devcon Titanium Putty. The pit was about 1/2" tall, the circumference of the cylinder, and about 3/16" deep. The repair worked fine.
A friend as used JB Weld. He reports good results as well, except the JB Weld used to smooth the combustion chamber area eventually burned out. I would expect that Devcon would burn out in that area also.
Rob
Old 01-26-2005, 08:31:04 AM
thanks for the replies. the pits are in the ring travel area
Old 01-26-2005, 10:28:46 PM
Larry Evans's Avatar
Larry Evans Larry Evans is offline
My brother and I have used J-B Weld on at least 2 different engines with good results. One is a 3 hp F-M Z that had 4 fairly deep grooves caused by an errant wrist pin. Filled grooves 15 years ago with J-B Weld and repair is still holding with at least 2 or 3 hundred hours on it.
As stated, area must be absolutely clean - use a Dremel tool or die grinder to clean out contaminated surface metal. After the epoxy just begins to set up put a piece of wax paper over repair and use a socket or similar metal cylinder as a small rolling pin to smooth and contour the surface. This will help to minimize removal of excess material later. The wax paper will remove easily after the epoxy sets up.
Larry
Pitted con. rod-use or don't use? Edwin Antique Gas Engine Discussion 4 02-24-2008 03:52:17 PM
pitted cylinder BobRR Antique Engine Archives 6 10-26-2002 02:40:24 PM
Pitted cylinder Stevewold Antique Engine Archives 6 07-29-2002 10:17:00 PM
3hp pitted Dennis Strayer Antique Engine Archives 0 01-13-2002 10:49:09 AM
pitted cylinder Vernon Antique Engine Archives 12 11-06-2001 10:23:46 PM
