La Flywheel Removal
this thread has 4 replies and has been viewed 1888 times
Old 01-31-2005, 10:41:00 PM
Justin Justin is offline
Default La Flywheel Removal
I have a very stubborn flywheel. I can only get it to move about 1/4", It will not come off any farther. I have tried about every thing I can think of but it still has not helped. So my next idea is to heat the hub up red hot or close to it, but I am wondering if this will hurt the crank shaft?? Or does anybody have any other ideas. I have removed a few other la/lb flywheels before and not had any problems.
Thanks Justin
Old 02-01-2005, 03:05:24 AM
JoeFisher JoeFisher is offline
Default Re: La Flywheel Removal
take the retaining clamp bolt out and drive a slow-taper chisel to spread the flywheel LIGHTLY.that should loosen the flywheelwith a dose of GIBB'S or thin oil. cold in central Texas Joe
Old 02-01-2005, 09:49:46 AM
I already tried that and it didn't seem to make any difference.
Justin
Old 02-01-2005, 11:19:23 AM
Keven Withers's Avatar
Keven Withers Keven Withers is offline
Images: 15
The heat wont hurt the crankshaft but could crack your flywheel. Make sure the end of the crank is not mushroomed over.
Old 02-01-2005, 12:01:23 PM
Email NOT Working
Justin, If you've moved it a quarter inch, it's as good as off! It's gotta come.
I would take some emery cloth and do a lot of polishing of the shaft. There must be a burr somewhere holding it. Maybe on the edge of keyway or somewhere. I would not try to heat the flywheel red hot, but it wouldn't hurt to just warm it up good. Of course, you have to work fast, because soon the crank will warm up too, and then you've lost your advantage.
I think the best bet would be to lock up the crank somehow and work the wheel off by twisting it back and forth while using a lot of PBBlaster or your favorite. The twisting motion will do a lot of good for you. That shaft has got to have a ding or something in it. When you polish it, you will begin to see where it is. When the shaft gets dented even a little bit, it displaces metal around the dent that must be filed down. Let us know how you do. Kevin
Flywheel Removal Roger Eldred Antique Gas Engine Discussion 6 12-29-2006 04:38:23 PM
Flywheel Removal? Mike Shearer Kohler Generators 12 03-03-2005 04:06:16 PM
flywheel removal Larry Pletcher Antique Engine Archives 11 08-04-2002 03:03:12 PM
F/M flywheel removal Jim Beachboard Antique Engine Archives 0 02-11-2002 08:42:58 PM
flywheel removal jd_mike Antique Engine Archives 9 09-07-2001 07:39:30 AM
