wearing properties of metal
this thread has 6 replies and has been viewed 1512 times
Old 01-31-2005, 11:34:25 PM
Sky
Lightbulb wearing properties of metal
i was wondering, what is the wareing property(i guess thats how you would say it) for Brass, Bronz, and just plain steel, maybee a hard wood such as maple?..but wood is not a metal.
what im trying to do is make a oversize points plunger for my Y model briggs & Stratton, the points plunger hole in the mag plate is wore(conveiniently) just enough were it will let oil bypass the plunger
it's not suppose to do that, so heres my situation, if i find a bronz or brass or steel rod of some sort, just the right size, i can make an over sized, metallic plunger, perferably of bronz, then every thing would be just fine again, i cant find the bushing you are really appose to use to make the plunger right again(NLA) (no longer available) so i have to make do with what inventions i do have, Hay, poor boy's have poor way's, but sometimes it works, and good! so my question is, if you were in my situation, what metal would YOU use? the points have some pressure to them, i think like 16 .OZ according to the book, so i have to take that into consideration as well, pressures and ware.
Any advise out there!?
Thank Ya!
Old 02-01-2005, 12:14:00 AM
Delco 32 Volt Delco 32 Volt is offline
Lightbulb Re: wearing properties of metal
What about using Micarta it wears better than bronze or brass ? Mcmaster Carr has it in rounds of many sizes. Good Luck!
Old 02-01-2005, 12:25:15 AM
Mac Leod Mac Leod is offline
Default Re: wearing properties of metal
wood swells, might not be a good idea...
Old 02-01-2005, 02:42:47 AM
JoeFisher JoeFisher is offline
Hows about teflon or nylon? Rod should be easy to get. cold in central Texas joe
Old 02-01-2005, 12:06:51 PM
Email NOT Working
I think you could buy a hard bolt at ACE HDWE and turn it down a bit. Even brass should last many, many hours and you're only running it occasionally right? Kevin
Old 02-01-2005, 03:23:22 PM
CJ Winslow
I have used the shank of a drill bit. You can get drill bits in most any size (give or take a couple thousandths). When I did it I cut it with a die grinder. You can also buy "Drill rod" through MSC or other suppliers that can be heated and hardened easilly. I think that MSC has it in increments of .001 which should be more than sufficent for you.
CJ
Old 02-02-2005, 10:41:03 PM
CharlieBiler CharlieBiler is offline
To make the plunger bushing, I recommend 360 brass. It is the freest cutting, most machinable, and it is forgiving on tools and reams. For a plastic bushing, use Acetron GP. It is extremely machinable and is self lubricating. It also will not swell or crack like nylon. Nylon is for doggie chew toys and beating lawyers.
To make the plunger, I recommend W1 steel. It can be had in just about any diameter. It is easy to work and when you get the job done, it can be heat treated with a propane torch and a can of water. Just remember to give an ever so slight spherical radius on each end. Those plungers are not flat on the end. W1 also likes to be finished with a piece of oil soaked crocus cloth at high speed. It will look like chrome and wear like glass if hardened to a full purple.
Best of luck and remember to have fun.
Properties of early paints and varnishes Reid Antique Gas Engine Discussion 26 11-21-2007 11:59:10 AM
pot metal Tim Rostar Antique Gas Engine Discussion 2 09-04-2005 08:13:55 PM
Lab Metal Greg Downard Antique Engine Archives 1 07-15-2004 09:19:24 AM
Rethreading pot metal? chuck kaufman Ore. Antique Engine Archives 4 02-05-2004 03:10:40 PM
CLR and pot metal John Rolli Antique Engine Archives 0 05-12-2003 09:40:07 PM
