Bosch AB33 Magneto
:confused: I have a AB33 mag that needs a charge. Can someone tell me the proper way to do this....
this thread has 2 replies and has been viewed 1063 times
Old 02-01-2005, 10:56 PM
Rich Martz's Avatar
Rich Martz Rich Martz is offline
Images: 23
Default Bosch AB33 Magneto
I have a AB33 mag that needs a charge. Can someone tell me the proper way to do this. I've heard ....remove the magnets and don't remove them. Just want to do it right.......Thanks ...........and Thanks Harry
Old 02-01-2005, 11:26 PM
Randy L Peterson Randy L Peterson is offline
Default Re: Bosch AB33 Magneto
The guy that charged mine did it with the Mag together just used a compass to figure out n and south put it on his charger and gave it the onion... Or a couple of 3 second bursts, works good now.. I have been told not to remove the magnets on these style magnetos..
Havin a blast preservin the past
Randy L Peterson
Old 02-02-2005, 01:10 AM
Rudy Rudy is offline
Card Sponsor
When you charge an AB-33 Mag you should charge it fully assembled. You put the mag on the charger so that it is laying flat or horizontially and put two aux. pole pieces on the end of the magnets closest to the springs. don't charge it on the breaker point side.also make sure the poles are north to south and vise-versa.
A little help please (Bosch AB33) George Vaughan Magnetos, Ignition Coils and Spark Plugs 2 04-03-2008 07:57 AM
bosch ab33 mag help BobM Magnetos, Ignition Coils and Spark Plugs 3 11-24-2006 12:32 PM
AB33 & Fairbanks F1 Magneto Collector Rings Andrew Albrecht Magnetos, Ignition Coils and Spark Plugs 0 09-09-2006 07:40 PM
Bosch AB33 Mag coil replacement Dave from Omemee Magnetos, Ignition Coils and Spark Plugs 17 08-12-2006 12:46 AM
Bosch AB33/AB34 mags Bob Kern Antique Engine Archives 1 04-20-2000 12:19 AM
