Onan CK-S Engine Oil
I recently got an old Onan/Miller welder. What kind of oil should I use in this old brute? Mod. #...
this thread has 5 replies and has been viewed 2807 times
Old 02-02-2005, 08:59 PM
desighitter desighitter is offline
Default Onan CK-S Engine Oil
Mod. # CK-S/259M, Ser. # 55B518817
What I drained out looked almost like automatic transmission oil????
Old 02-04-2005, 09:06 PM
Keith Kessler Keith Kessler is offline
Default Re: Onan CK-S Engine Oil
Hi,
According to the factory engine manual in normal operation, 30F to 90F, SAE 30 Detergent oil. In otherwords, your normal run of the mill modern single viscosity "30" oil would be fine. If the suff that you drained from the engine looks thin, watch carefully after the oil change for an increase in oil level with a likely decrease in oil pressure. Oil pressure must be monitored at running temperature. This applies to CK-S engines with a mechanical fuel pump. If the diaphram is old and leaking, it is thinning your oil with petrol. Watch for this in any old engine with antique rubber parts.
Hope this helps.
Keith Kessler
Old 02-04-2005, 10:41 PM
Sure enough. After trying to start it, the problem seems to be an old worn out fuel pump. The gas was probably leaking through the diaphram. Any ideas on how I can fix it. Know of anywhere I can get a replacement fuel pump?
Old 02-05-2005, 11:15 PM
Hi,
It might not be a bad idea to put a gravity feed tank going directly to the carb to verify the unit is all there and working. Be careful and make sure that you don't have leaks. Engine fires are not fun.
www.perr.com is one place to get parts. They seem ok but I have no idea how they stack up with the rest of the dealers. They have been helpful for me so far. I hate to say it but you could also search ebay to see what turns up for CCK parts.
Good Luck,
Keith Kessler
Old 02-06-2005, 07:45 AM
Billy J Shafer's Avatar
Keith is correct about the oil and the fuel pump.The pump was the first place I always looked at when I had gas in the oil.When it leaked the fuel dumped into the oil.I think the pumps are still in the system,you can also try ebay or Bruce may have one.Alot of welders I know would change to a electric pump,then they did not have to worry about being on a job and the pump leaking fuel into the oil.If you do this be sure and get a low pressure pump.Four pounds is the max you can use.
Old 02-18-2005, 11:12 PM
Gunny Gunny is offline
Yup. Go with an electric if you can.
Onan BH engine? Bahmi Small Air Cooled Gasoline Engines 4 03-14-2008 04:21 PM
onan engine RichardKCMo Small Air Cooled Gasoline Engines 0 12-25-2006 11:21 PM
New and need help with Onan engine Chuck Svihlik Onan Generators 4 06-08-2006 01:39 PM
Onan engine? Craig A Antique Gas Engine Discussion 2 01-09-2006 07:28 PM
Onan MIL Engine Keith Patrick Onan Generators 0 04-17-2003 04:48 PM
