F Oilpull info needed
I am currently gathering info for the 15-30 F Oilpull heavyweight. I am building a scale running...
this thread has 2 replies and has been viewed 879 times
Old 02-03-2005, 02:44 PM
Forrest A's Avatar
Default F Oilpull info needed
I am currently gathering info for the 15-30 F Oilpull heavyweight. I am building a scale running model and need either drawings of the motor, drivetrain and anything else that would assist me. I have taken lots of external pictures but would like some crankcase shots. I'm including a shot of a freelance Oilpull I built over the period of about 8 years.
Old 02-04-2005, 09:24 AM
Russ Herrstrom Russ Herrstrom is offline
Thumbs up Re: F Oilpull info needed
I do not have any oil pull info but just wanted to say that your freelance oil pull model looks great! What did you do for the engine on your freelance?Would you happen to be the Forrest who write's article's for Home Shop Machinist? if so keep up the good work, I really enjoy your article.
Russ
Old 02-07-2005, 03:16 PM
Forrest A's Avatar
Default Re: F Oilpull info needed
I've been in Modeltec a couple of times. I took some photos for an article and front cover of a recent HSM issue but the gentleman that writes the articles is someone else. The motor is made from two pinball solenoids. The Tractor should be at NAMES if things go as planned. I also will have a Prony brake made to test the tractor on.
Forrest
15-30 F Oilpull Measurements Needed Forrest A Antique Tractors - Old Iron Lugs, Cleats and Tracks 0 02-08-2007 03:09 PM
oilpull 20-40 /G / R.P.M. Wayne Riedlinger Antique Tractors - Old Iron Lugs, Cleats and Tracks 0 10-04-2006 03:06 AM
Building an F Oilpull Forrest A Antique Gas Engine Discussion 8 09-07-2005 03:40 PM
F Oilpull gears Kevin A. Behnke Antique Tractors - Old Iron Lugs, Cleats and Tracks 0 02-11-2005 05:50 PM
3rd model oilpull kyle blankenship Antique Engine Archives 2 02-25-2002 08:06 AM
[IMG] code is Off
