Model Engine Ignition-Advice needed
this thread has 1 replies and has been viewed 1603 times
Old 02-06-2005, 11:44:26 AM
GarryB
Default Model Engine Ignition-Advice needed
Question??When the contact points and the cam lobe contacts(to set up the firing-Should there be sparking-(lots of sparks)that sometimes jumps across to the timing lever-Is that normal??-This engine fires(pops) a couple of times-then stops.
-Buzz coil/battery-seems to be hooked up right.
-Timing OK-about 6 degrees BTDC
-Is getting fuel
-Compression seems ok
Any help would be appreciated
Garry
Old 02-06-2005, 04:22:37 PM
Frank K Jr.'s Avatar
Frank K Jr. Frank K Jr. is offline
Default Re: Model Engine Ignition-Advice needed
Hi Garry, Check to make sure the buzz coil is hooked up correctly. See the pic of the drawing in this thread. http://www.smokstak.com/forum/showthread.php?t=18525
You should be able to see a small spark at the points but nothing that should jump.
Your timing is correct if you are using gasoline. If you are using coleman fuel change timing to about 5 deg after TDC. I have an 3/4" bore Upshur that runs very well at this setting when run on coleman. What kind of engine are you trying get started?
Hope this helps,
Frank
CCK, JB Muffler Advice Needed RichardR Onan Generators 7 03-19-2008 01:04:31 AM
Monitor Pump Jack Engine- Advice Needed SMertz Antique Gas Engine Discussion 18 12-16-2007 07:52:16 PM
Model engine ignition systems Kelly Tytlandsvik Scale Model Engineering 2 04-23-2007 10:24:04 AM
Advice needed Benny Mckheean in NC Antique Engine Archives 7 01-14-2004 06:26:52 PM
Advice needed Mike Austin Antique Engine Archives 2 11-06-2000 04:22:27 AM
