Drilling Holes in Glass
this thread has 4 replies and has been viewed 2802 times
Old 02-07-2005, 10:14:18 PM
garry brown garry brown is offline
Default Drilling Holes in Glass
My wife needs me to drill some 1/4" holes in a glass dish to make a flower pot. I thought of using a tile drill on my die grinder. Any better ideas? Is glass dust toxic like blasting sand?
Old 02-07-2005, 10:28:09 PM
Fred Prichard Fred Prichard is offline
Default Re: slightly off topic... drilling glass
I use a piece of brass tubing of the right OD, 1/4" to drill a 1/4" hole, & coarse Clover grinding compound diluted with a little oil in my drill press on slow speed. Keep moving up & down with firm pressure & it grinds a nice smooth hole thru any thickness of glass. Just did some new wine glass oiler glasses, over 1/4" thick with a 1/2" hole, took about 30 minutes. Fred Prichard, New Hampshire
Old 02-07-2005, 10:32:32 PM
RHudson RHudson is offline
Lowes or your local hardware store should have a drill for glass. it will look like a spear point on the end. basically you take modeling clay and build a circular dam around the spot you want to drill the hole. keep the clay dam full of water so that the drilling is done under water. this is done to keep the drilling action cool. take you time and use little down force. as the drill breaks (sorry about the wording) through, take care to reduce drilling force to keep the drill from grabbing or shattering the glass. i always say a little prayer before starting, and it seems to work.
Old 02-08-2005, 12:21:34 AM
Rudy Rudy is offline
Card Sponsor
Yes glass dust is toxic. Glass is made of sand heated red hot. You can get silicosis from the dust. My wife does stained glass work , and the grinding dust is brutial on the lungs.
Old 02-08-2005, 08:15:14 AM
Chris Curtis
I drilled many 1/2" holes in glass block this winter with a diamond bit in a Dremel tool. I drilled a hole on a piece of wood and clamped that to the block for a guide then drilled the glass at full speed under water. It drilled fast, clean and easy. Just be careful not to get the tools motor wet.
Old Drilling Rig David Greenwalt Oil Field Engines 3 12-20-2009 09:46:55 AM
Well drilling tbastin Antique Gas Engine Discussion 13 03-29-2008 05:24:42 AM
Little holes to make big holes ? Pete LaBelle Steam Stationary Engines, Traction Engines, Steam Boats 9 10-29-2006 09:30:02 PM
HELP!!!! Drilling holes in hardened steel washers. Gene O. Carpenter Antique Gas Engine Discussion 15 03-20-2005 04:11:13 PM
Starr Drilling Machine Carrie Darras Antique Engine Archives 2 07-22-1999 09:01:25 PM
