Dragsaws
this thread has 1 replies and has been viewed 1310 times
Old 02-08-2005, 07:09:27 PM
Andre Blanchard's Avatar
Andre Blanchard Andre Blanchard is offline
Default Dragsaws
Anyone have any info on dragsaws from the late 1800's early 1900's, that were used for cutting stone. Otherwise know as mudsaws.
Thanks,
______________
Andre' B. Clear Lake, Wi.
Old 02-09-2005, 01:44:34 PM
Default Re: Dragsaws
Thanks,
______________
Andre"
I did a search and this all I could find. Hope it helps a little.
Mud Saws
... Not all slab saws use diamond blades. An older style is called a mud saw and they are still available as used equipment. A mud saw has no abrasive attached to the blade. Instead, the blade runs through a troth of abrasive, which is usually silicon carbide. This is the "mud." It carries some of the abrasive with it on each pass.
... The primary advantage of a mud saw is economy; they cost much less than one with a diamond blade. Their disadvantage is that they require more maintenance. The abrasive breaks down with use and the saw must be shut down and recharged periodically. Properly set up and maintained, a mud saw works superbly.
Jim
Dragsaws Otto Ray III Garden Tractors / Mowers / Scooters 1 11-15-2005 12:52:37 AM
Buckeye Harvester Dragsaws Adam Cottrill Antique Engine Archives 0 01-17-2004 04:55:06 AM
