Help with flat belt pulleys
this thread has 2 replies and has been viewed 2198 times
Old 02-14-2005, 01:27:26 AM
CJ Winslow
Angry Help with flat belt pulleys
I recently came across a source for some nice flat belt pulley material. I have three drive wheels for crane systems in a factory. The pulleys have a rubber coating on the outside edge that has worn off and rendered them useless as drive wheels. I can get the rest of the rubber off easilly enough leaving me with a nice rough cast wheel that is already bored out. The problem is that the outside is still a rough casting surface that I need to turn down. I know that flat belt pulleys have a crown to them I was wondering how many degrees this crown is so that I can go and turn them to the right angle. I am putting these on engines that are 1.5 to 2 hp and was wondering how wide the minimum width should be - in othere words how wide of a belt do I need to transmit 2 hp? The pulleys are about 4" OD. Lastly - the Jaeger that I am putting one of them on only has about three inches of crank shaft exposed to put a pulley on. What can I do to make sure that when I have the pulley on that the belt does not rub on my flywheel and wear off my fresh paint job - that would make me .
Thanks for the help - CJ
Old 02-14-2005, 09:42:00 AM
Harvey Teal Harvey Teal is offline
Default Re: Help with flat belt pulleys
The max crown should be "1/8 inch per foot across the face",
which works out to 1/4" in the diameter of a 12" wide pulley.
A single ply leather belt will transmit 1.8 HP per inch of width
at 1000 feet per minute. So roughly figgerin', a 4 inch pulley
at 500 rpm, being about a foot in dia, will give you about 500 fpm,
or 0.9 HP per inch of width. Go with a 3 inch belt to handle
slippage etc. Make up a big washer using some of my handy dandy
Teflon fiberglass laminate, and run it between the pulley and FW.
Old 02-14-2005, 02:01:57 PM
CJ
When I made the pulley for my tractor, ( 6" dia. X 5" face) I cut the crown at 2 degrees. The belt tracks with no problems.
Jim
Flat Belt Availability Chris Euart Farm + Industrial Antiques and Collectibles 6 07-29-2012 08:55:55 AM
New Steel Flat Belt Pulleys Jeff Smith Steam Stationary Engines, Traction Engines, Steam Boats 4 01-08-2007 04:34:24 PM
FLAT BELTS & PULLEYS David M. Lyon Antique Engine Archives 6 02-06-2002 11:56:43 PM
Re: Belt Pulleys-Don't just sit there, Do somethin Randy Antique Engine Archives 4 01-06-2000 05:35:21 PM
Belt Pulleys-Don't just sit there, Do something! Allen Antique Engine Archives 4 01-06-2000 12:59:05 AM
