Engine Decals
this thread has 4 replies and has been viewed 2022 times
Old 02-14-2005, 08:56:00 PM
Mark K Mark K is offline
Default Engine Decals
Just wondering what type of decals to use? The peel and stick vinyl type or the water transfer type. Is one type better? They will go on a freshly cleaned and painted, but not smoothed with filler, engine. {Cast iron} Thanks
Old 02-15-2005, 12:17:22 AM
Bob Ronning's Avatar
Bob Ronning Bob Ronning is offline
Images: 4
Default Re: Engine Decals
I have the Sandwich in vinyl stickers, and have sold over 50 of them.. I like this type a lot better than the old water transfer, the newer vinyl look so much better, even than the older vinyl. I put some of the older peel and stick on my 18-32 case and the color even faded out. if vinyl is available for the engine you are working on I would use it. Bob
Old 02-16-2005, 06:38:25 PM
Dale Russell Dale Russell is offline
I have the 4 color "ROLLR" decals for NOVO engines with the Timken roller brgs. on the mains. Also have repo's of the "INDEPENDENT HARVESTER" decals. [early and late]
Old 02-17-2005, 02:25:00 PM
BannerBoy's Avatar
BannerBoy BannerBoy is offline
In my personal experience, water transfer decals work better than vinyl stickers for applications that aren't almost perfectly smooth (I'm an avid military scale modeler as well as an engine collector). both types have their respective merits, but the water transfers will snuggle down into the depressed areas on the castings a lot better since the film on a true decal is much thinner than vinyl. After placing a decal and letting it dry (I usually wait 2-3 days) it should be sprayed with a good clear coat that is compatible with whatever paint you happen to be using as this will protect the decal and hide the lines where the film is.
Old 02-18-2005, 11:36:36 PM
G.Ledger G.Ledger is offline
I like the water decals for some of the same reasons as stated, but I haven't found a good outlet for them. Does anybody know where a person can get them for say a IHC engine ( LB, M, Mogul)?
Engine Decals Chris J Antique Gas Engine Discussion 9 11-05-2007 10:02:39 AM
Engine Decals Ackman Antique Gas Engine Discussion 0 04-01-2006 01:01:30 PM
Engine Decals Gary Pflum Antique Engine Archives 5 12-11-2003 11:02:49 PM
IHC LB engine decals Stevie Antique Engine Archives 1 09-12-2002 10:50:39 AM
engine color and decals . Dan Nelson Antique Engine Archives 0 06-29-1999 10:38:37 PM
