Need Help With My Woodwork
this thread has 4 replies and has been viewed 950 times
Old 02-20-2005, 09:10:20 PM
Dan Bogart Dan Bogart is offline
Default Need Help With My Woodwork
Working on a rusty Stover that I want to leave as I found it, But I had to make new skids for it. I wanted oak but I ended up with Alder(?) I would like to age these brand new boards. Anyone have a trick for this or should I just paint them some drab color? Thanks, Dan
Old 02-21-2005, 12:18:50 AM
Mac Leod Mac Leod is offline
Default Re: Need Help With My Woodwork
well, you can ... 1, spray with wd 40 (try in small area to see what you think) 2, let it sit out for a long time 3 wipe with old used nasty motor oil or 4 use rotten wood.
hope this helps
Old 02-21-2005, 12:50:55 AM
BobRR BobRR is online now
Used motor oil! BobRR
Old 02-21-2005, 12:56:05 AM
Mac (Bob posted as I was writing) has some good ideas! I'd use a torch to partially "distress" the surfaces paying particular attention to the ends, then beat the hell of it with a chain or hammer to give it character (this IS called distressing), use a dark stain and while the stain is still tacky wipe it with a dirty, filthy, oily rag. You might even dab the oily rag in some plain old dry sand as you "finish" your lumber. You'll have skids that'll look like they came with the engine. Anything you try to apply to the unblemished surface will just wind up looking the same all over---NOT the effect you're after.
Old 02-21-2005, 07:21:52 AM
J.B. Castagnos J.B. Castagnos is online now
A sand blaster will remove the soft wood leaving the hard grain, same as the weather. A wire brush on a grinder will smooth it out, distress and stain will finish.
