Kohler Generators
Kohler 4.5cm21 generator help needed
this thread has 30 replies and has been viewed 17308 times
Old 02-24-2005, 12:09:13 PM
2000Trooper 2000Trooper is offline
Question Kohler 4.5cm21 generator help needed
I just got a Kohler generator model 4.5cm21 with a k341ep engine. I was able to go to the Kohler web site and get the manuals for the engine. Does anyone have schematics for the generator part of the unit? This unit was in an old RV. I’m trying to make it work for emergency duty.
I will try to post a picture later today.
Any help will be appreciated. Thanks
Old 01-27-2006, 10:25:56 PM
Robert Fender Robert Fender is offline
Default Re: kohler 4.5cm21 generator help needed
I searched the Kohler web site and was unable to locate a manual for mine. Is yours in a PDF format?
Did you ever get a schematic? If so I think I need the same. However, my model # is:
Model #: 4.50M21-RV
Serial #: 042471
Spec #: 13912A
Watts: 4500
Hertz: 60
RPM: 1800
KVA: 4.5
Amps per Terminal: 37.7
Class: F
AMB: 40 centigrade
Battery Charge 12 Volt, DC 7 Amp
Is this the same as yours?
Old 01-27-2006, 10:41:32 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: kohler 4.5cm21 generator help needed
I have a .PDF file for a 4.5CKM21-RV I am wondering what the difference
between that, and the 4.5CM21-RV, which my neighbor has, would be?
If one of the Kohler Gods could tell us, I for one, would greatly apperciate,
and bow down to the east, multiple times.......
Bruce in alaska
Old 01-27-2006, 11:44:55 PM
Can you send the pdf and I willlet you know, since I have the 4.50M21-rv.
Old 01-28-2006, 03:33:07 AM
ListerDiesel's Avatar
Bruce in alaska
According to the compilation of info that we put together, the K stands for a Kohler engine, B for Briggs & Stratton.
http://www.oldengine.org/members/die...KohlerCode.htm
If there is neither letter, I haven't a clue! :-))
Possibly it was left out if the engine was only available as a Kohler.
Peter
Old 05-11-2006, 12:13:49 PM
meckanic69 meckanic69 is offline
If you look under the "COntroller Box", it may be taped to glued to the underside. If not, let me know and I can try to copy it and fax to you
Meckanic69
Old 05-29-2006, 09:27:22 AM
Randy W. Randy W. is offline
Bruce in alaska
The 4.5ckm21-rv 1s a two cylinder horizontal opposed engine. The 4.5cm21-rv is a single cylinder vertical engine.
Randy
Old 05-29-2006, 09:48:09 AM
File attached. Good luck.
Randy
Old 08-05-2006, 01:50:14 PM
dozer dozer is offline
Default Re: Kohler 4.5cm21 generator help needed
Randy, that's exactly the schematic I need !
But I can't quite read the little numbers and such.
My software says it's only 200dpi.....any chance you could rescan it at 300dpi or 400dpi, and post again?
That'd be great!
thanks very much,
Richard
Old 08-05-2006, 04:29:25 PM
BTPost's Avatar
Images: 1
Talking Re: Kohler 4.5cm21 generator help needed
I would like a copy of that schematic in whatever the maximum resolution
available, as well as a copy of any manual, if available, as well
Bruce in alaska
Old 03-12-2007, 01:02:59 PM
gle gle is offline
yes i do my friend call me ask for glen jr 1 760 868-6155
Old 03-12-2007, 01:13:20 PM
gle gle is offline
i need the relay control box with the three relays+start/stop-switch complete can someone hook me up please call me 1 760 868-6155 ask for glen jr thanks
Old 03-03-2008, 03:22:42 PM
frankacri frankacri is offline
Cool Re: kohler 4.5cm21 generator help needed
Bruce in alaska
my son just bought a4.5ckm21-rv and you must be the only person on earth with a manual for it . Can you email this .pdf and make me the second person on earth.thanks, frank... frank.acri@gmail.com
Old 04-03-2008, 01:24:09 PM
Clampinator Clampinator is offline
Howdy Im looking for a manual for a Kohler 4.5 CKM21-RV that Im trying to get running. It smells varnished and I think it needs a carb rebuild. So Im looking for a kit now. Any help out there would be greatley appreciated. Wayne
Old 05-10-2008, 11:52:09 PM
cha22cho33 cha22cho33 is offline
Post Re: Kohler 4.5cm21 generator help needed
Hi !!! every one. I just bought an old but very clean Kohler 4.5CM21-RV, it strarts right away, and runs continuously but every 5 seconds deccelerates it shelf and then runs and again deccelerates..... but never stops 'till I stop it. could some boody out there help me with some advice ?. Plus I need the owner manual to see the wiring diagram. I'll be glad to pay you for a copy and delivery or send by e-mail trujilloefrain@yahoo.com. I really will appreciate any help. Ephrain
Old 05-11-2008, 12:37:02 AM
I forgot to say it expends a lot of gas like 32 oz. in 10 minutes. Ephrain
Old 05-11-2008, 12:18:28 PM
BTPost's Avatar
Images: 1
These units have an "Idle Down" mode, where the engine goes from
Generating Rpm to Idle, when there is No Load present. If you connect
a load, (Light Bulb), the unit will sense it and stay at Generating Rpm.
It is considered a "Feature", not a malfunction. It is designed to save
fuel, when not loaded.
Bruce in alaska
Old 11-24-2009, 12:29:00 PM
jlaske jlaske is offline
Hi ,i am also in need of wiring diagram for 4.5cm21 4500 generator.It runs but dies when i release start button.Thank you My email is jlaske69@hotmail.com if anyone can help me please
Old 06-28-2010, 11:39:08 AM
melzer melzer is offline
Hello,
I saw your post this morning and I DESPERATELY need a .pdf manual for the model
4.5km 21-RV Kohler generator you mention on smokstak.com
Would you kindly email the pdf to mels.mail@juno.com and thank you in advance.
Mel
Old 09-12-2010, 02:45:04 PM
hlflorek hlflorek is offline
I am also in need of the PDF manual for the 4.5CKM21-RV.
My email address is waterlover65@comcast.net
Kohler 4.5CM21-RV Gen Set ChrisMar Kohler Generators 18 10-20-2014 05:30:37 AM
kohler 4.5cm21 rv genset need help partcat37 Kohler Generators 1 12-11-2006 07:20:49 PM
KOHLER 4.5cm21-rv LP mrtune Kohler Generators 8 11-10-2005 11:27:23 PM
Kohler 3.5CM21 gas generator Lynnnn Kohler Generators 0 05-15-2005 07:28:38 PM
want 240 from 120 kohler 4.5cm21-rv dpotter Kohler Generators 0 11-20-2004 07:59:11 PM
