Buzz coil help
this thread has 2 replies and has been viewed 2427 times
Old 02-24-2005, 02:43:59 PM
John Rigter John Rigter is offline
Question Buzz coil help
I need some help on putting together a Bozzcoil. What will happen when you wire a 2mfd cap across the coil terminals instead of using a .5 to 1mfd cap and a 500 to 1000 ohm resistor. I bought one like this it seems to work okay but before I put myself a couple more together I want to know if that will work longterm . Go easy on me I don,t have much electronic knowledge. Thanks in advance . HARRY'S is great, people not online don't know what they're missing.
Old 02-25-2005, 11:17:11 AM
Elden DuRand's Avatar
Images: 6
Default Re: Buzz coil help
John:
If you're talking about a Model "T" Ford coil or similar, they need about 0.22 microfarad at 600 Volts for a condenser.
If you're talking about one of the arrangements where you use an automotove relay as a buzzer to drive a regular ignition coil, use whatever gives a nice buzz on the relay. I like the idea of the larger capacitor and resistor. This should make it easier on the relay contacts.
I think for the relay buzzer capacitor, I'd go for one with a 50 Volt or higher rating.
On the auto ignition coil side of the arrangement, just use a regular auto condenser.
Take care - Elden
Old 02-26-2005, 02:28:30 AM
Smile Re: Buzz coil help
Thanks alot, I'm using a coil and relay, The one I bought just has a 2.0 cap wired in, it sure packs a lot more wallop than the T buzzcoil, I hope it holds up, even with all new parts it's pretty cheap John
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08:54 AM
buzz coil Oscar Allen Antique Engine Archives 2 06-03-2004 08:42:59 PM
BUZZ COIL HELP JEFF B Antique Engine Archives 7 12-10-2001 10:38:05 AM
buzz coil ,how to rig Steve Gerot Antique Engine Archives 1 07-26-2001 12:39:07 PM
buzz coil Darrell Antique Engine Archives 17 06-21-2001 01:08:10 AM
