rust removal instructions?
this thread has 7 replies and has been viewed 1431 times
Old 03-08-2005, 12:59:19 AM
Sky
Exclamation rust removal instructions?
could i get some simple what do you call it? electroalisis instructions for removing rust, i want to know how you set this operation up with a battery and such, what is needed to do this? i hope it's something simple cuz i dont have anyway to get creative with this, such as finding special things and machining.
Thanks for the help!
Sky
Old 03-08-2005, 03:40:48 AM
Franz Franz is offline
Registered 0
Default Re: rust removal instructions?
http://www.shopfloortalk.com/forums/...ead.php?t=1695
Old 03-08-2005, 10:13:15 AM
Orrin Orrin is offline
It's possible to provide the basics of electrolysis in a short paragraph; but, I found out early on that when given only the bare essentials many people make mistakes and wind up being disappointed in the process.
So, I prepared a handout to go along with my electrolysis demonstrations. It's not Web friendly, but if you go to the Web page linked here, you can print it out for yourself and find out what I've learned in close to a decade of experience with the process.
http://users.moscow.com/oiseming/rustdemo/rustdemo.htm
Orrin
Old 03-08-2005, 01:55:01 PM
Sky
would this work for rusty gas tanks too?
Old 03-08-2005, 08:51:17 PM
Not on the inside !!!!
Jim
Old 03-08-2005, 09:15:29 PM
Yes, if done properly, it will work on gasoline tanks.
This is covered in my handout. If you read it many of your questions will probably be answered.
Orrin
Old 03-09-2005, 01:51:11 AM
Sky
Thanks for the help and info guys!
Doing these rusty jobs will rilly make it easier on me now.......i hope!
Thanks again Guy's.
Old 03-09-2005, 04:44:12 AM
Images: 4
Several years ago I purchased a small 5 hp Honda powered pressure washer for about $399.00. I think it's about 2300 lbs/p/sq/inch at about 2.5 or 3 gallon per min.
At about the same time I went to the Tulare Ag Show and saw someone demo a larger pressure washer with a sand blasting attachment.
Upon my return home I sent away to Northern Tools for a sand blasting attachment that cost about $60.00, even though it called for a slightly higher pressure and larger volumn pressure washer.
It has worked great although I have to use somewhat fine silica and ocassionally have to move the pick up tube in the 5 gal bucket of sand to keep it working well.
It not only works well but it keeps the dust down and minimizes the protective clothing I need to use it. I use eye protection and handle it with respect. I just take the thing I have to blast out on the lawn over a piece of old plywood and blast away. The sand and debris just sink into the lawn. I have plenty of lawn to move around on so there is no cleanup.
I had previously purchased a pressure tank type sand blaster and only used it once. I will never use it again as it was a very unpleasant experience and I had to stop often to wait for my 5 hp electric compressor to catch up.
Last summer I rebuilt a small boat trailer that had been damaged by salt water and after replacing the axel and springs I blasted the hole thing down to bare metal and good paint in about 30 minutes. I would estimate that a 1 1/2 hp hit and miss engine would take less that 1/2 hour to take down to bare iron.
I have several such engines that I will do this to this summer. I will take precautions on the bearing surfaces and the bore and remove any brass or soft parts prior to blasting of course
The process is so clean that the man demonstrating the larger washer and sand blaster at the Ag Show did so right there with people passing by just a few feet away. He used a face shield only and had on his street cloths. I didn't notice if he had on boots or not but he convinced me that sand blasting didn't have to be so disagreeable.
I intend to use this method of rust removal on many of my future projects
Dick
Rust removal john hatc. Small Air Cooled Gasoline Engines 6 07-11-2006 02:14:08 AM
Rust Removal Benny Mckheean Antique Gas Engine Discussion 4 03-03-2005 08:47:40 PM
Rust Removal MICHAEL G. ESCH Antique Engine Archives 6 10-24-2003 12:34:14 PM
Rust Removal Fred Van Hook Antique Engine Archives 2 10-14-2002 10:27:12 PM
Rust removal... Robert Antique Engine Archives 6 09-07-2000 08:09:00 AM
