Fm-z, 1.5hp, Governor Disassembly
this thread has 2 replies and has been viewed 1123 times
Old 03-14-2005, 12:45:42 PM
Dave from Omemee Dave from Omemee is offline
Default Fm-z, 1.5hp, Governor Disassembly
I HAVE A 1.5HP FM TYPE Z ENGINE WHICH i AM TRYING TO REBUILD. HOW DO YOU GET THE 12 TOOTH GEAR OFF OF THE GOV SHAFT? IS IT THREADED ON?? tHE SHAFT IS WORN QUITE A BIT SO i WOULD LIKE TO PUT BUSHINGS IN IT.
THANKS
DAVE FROM OMEMEE
Old 03-14-2005, 06:14:56 PM
Larry Larry is offline
Default Re: Fm-z, 1.5hp, Governor Disassembly
Hi Dave, The best I can remember is that the Gov. Weights You have to hold them and they UNSCREW... Standard threads left for OFF, They are Probably real Tight May have never been off since factory..Larry
Old 03-15-2005, 12:28:46 AM
ErikG ErikG is offline
Hey Dave, Check the archives, there was some discusion on this in an earlier post. I took one apart this winter and it unscrewed like Larry said. Mine came apart pretty easy. Be careful not to break the weights or the yoke when clamping/holding it. I believe that was the info posted in the archived thread. The shaft and the gear are 1 piece. I have a 5 hp ZB gear that I could not seperate. I gave up for fear of breaking it. Some day I will re-attempt, it needs a bushing also.
Good Luck,
Erik Grund
Kohler Disassembly Mike Cushway Kohler Generators 12 06-12-2013 08:38:10 PM
Welder generator disassembly elnav Welding Shop 1 10-21-2007 07:15:17 PM
Lalley light Disassembly John Dungan Antique Gas Engine Discussion 0 01-21-2007 11:56:39 AM
Stover KA2 Governor Shaft Disassembly ? SteveJ Antique Gas Engine Discussion 0 04-30-2006 10:26:57 PM
Disassembly of piston David Showerman Antique Engine Archives 0 07-22-2000 12:19:21 AM
