Electrolysis question, need advice
this thread has 3 replies and has been viewed 1283 times
Old 03-17-2005, 07:19:35 AM
David OBrien David OBrien is offline
Default Electrolysis question, need advice
I am about to try my hand at electrolysis on a badly frozen Maytag cylinder and piston in an attempt to free the piston. My question is this will the process harm the bronze connecting rod as this is the part I am trying to salvage? Any advice you guys can give will be greatly appreciated, thanks to all.
Old 03-17-2005, 09:42:15 AM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
Default Re: Electrolysis question, need advice
Just yesterday I pulled out an assembly for an F-M water pump that had a brass rod. Did not see any ill effects on the brass which is a brother to bronze. I'd go ahead and try it. Maybe check it 5 minutes later and increase the interval as time goes on.
I've read where electrolysis only works on ferrous metals.
Good Luck
RickinMt.
Old 03-18-2005, 12:33:52 PM
Daniel Dorece Daniel Dorece is offline
As long as you hook it up the right way you can use this process on any metallic part. I have cleaned iron,steel,bronze,brass,die cast,copper,etc. This is the same process that treasure hunters use to clean gold and silver. I use 316 stainless anodes. They last for ever and the corrosion from the parts being cleaned just sinks to the bottom of the tank. I just purchased 3x3x7 Ft.stainless tank and I am going to try using the whole tank as an anode to clean very large parts. I use old computer power packs to power my cleaners. They are cheap and usually have a 3 volt output and high amps which seems to work better then higher voltage.
Dan
Old 03-18-2005, 07:40:05 PM
Elden DuRand's Avatar
Images: 6
Thumbs down Re: Electrolysis question, need advice
Dan
Dan:
I had a 50 gallon stainless steel photographic stop bath tank, complete with the pump, etc. I thought it would be nice to use the entire tank as a cathode.
Pretty quickly, I was warned-off of this idea because in the electrolysis process, the chrome comes out of the stainless steel and goes into solution as a dangerous chemical.
BTW, while I used my SS tank, it worked fine but did get a yellow (chrome) something-or-other crud on the electrolyte. Too bad. it worked fast, too.
Take care - Elden
electrolysis question Chuck Kaufman Antique Engine Archives 2 10-18-2004 08:47:02 AM
Another Electrolysis Question Charlie Allen Antique Engine Archives 13 01-05-2004 10:57:31 AM
Electrolysis Question Dick Bauer Antique Engine Archives 6 01-03-2004 02:52:33 PM
question about electrolysis Willie Horness Antique Engine Archives 7 07-20-2003 10:58:56 PM
Electrolysis question Kent Ashley Antique Engine Archives 2 04-23-2001 07:54:06 AM
