SPARK POWER FOR MAKE & BREAK
this thread has 2 replies and has been viewed 1763 times
Old 03-17-2005, 05:53:03 PM
AirMail AirMail is offline
Default SPARK POWER FOR MAKE & BREAK
I'm trying to get the old Domestic Make and Break Pump going,(saw it run as a kid)..but don't know what they used for spark power going to the breaker. I just remember a battery being hooked up...I suspect some type of coil. any help with thanks.....Airmail180@AOL.Com
Old 03-17-2005, 07:47:07 PM
kerogas's Avatar
kerogas kerogas is offline
Images: 11
Default Re: SPARK POWER FOR MAKE & BREAK
If it has ignitor ignition you can use a lot of things ,an actual low voltage coil being one , florescent light ballasts another , the stator from an alternator , I have used a regular auto coil (the two little posts only) and the magnet in a ford starter solenoid . Look on harrys igniton page and all will be explained as to the "whys" its just a simple electromagnet .
If you have a spark plug - that will require a buzzcoil and a timer . a different matter entirely .
Old 03-18-2005, 03:29:14 PM
Dieter Paul
Hi
Check out page 8 of Domestic Type A Starting Instructions on the following link. This will show you a schematic of how to hook up a type A engine.
http://www.domesticengine.com/Domest...Brochures.html
Regards
Break through (maybe) Farmboy1 Antique Gas Engine Discussion 5 01-02-2008 12:20:26 AM
Make and break ignition and a model T coil BobM Antique Gas Engine Discussion 4 12-30-2007 09:33:23 PM
"Make and Break Spark coil" work on any engine? Chris Kirk Antique Gas Engine Discussion 1 08-19-2006 09:23:55 PM
IHC 6 M hammer break repair RHudson Antique Gas Engine Discussion 4 06-08-2005 10:45:03 AM
disc break Chuck Franklin Antique Engine Archives 1 11-26-2001 01:12:47 AM
