14/28--16/30 question
If you can stop laughing long enough--please asn this question--on this tractor?? i recently...
this thread has 6 replies and has been viewed 867 times
Old 03-19-2005, 12:48 PM
Ihorse Ihorse is offline
Default 14/28--16/30 question
If you can stop laughing long enough--please asn this question--on this tractor?? i recently purchased---do these tractors have a [letter] disignation? such as -H--A--B--X-Z whatever??
thanks d,j,
Old 03-19-2005, 02:47 PM
Ken Majeski's Avatar
Images: 34
Default Re: 14/28--16/30 question
The 16-30 is the model H. There is a serial number break about 1920 and some early tractors can have Higher numbers than the later ones... To further add to the cornfusion.... Don't know if the 14-28 was ever called the H or not....?
http://www.smokstak.com/gallery/files/3/7/rumely_h.jpg
Old 03-19-2005, 05:55 PM
Bob Cutler Bob Cutler is offline
Ken thats one bootifull machine.
Old 03-20-2005, 01:34 AM
If it's a TRUE 14-28 it SHOULD have ignitors.
Old 03-20-2005, 03:14 PM
Images: 34
Right BUT... Many of them were changed to spark plugs with a kit from the factory... BUT it should then have the plugs in adaptor castings bolted to the block and there should be places for the igniter pushrods. Lots of other differences also, Such as the flywheel and square tanks instead of round ect...
Old 03-20-2005, 03:19 PM
Images: 34
Well... It's not quite as nice as it looks... I was in a hurry when I put it together and cheated a few places.... Like the 30 gallon barrel for a fuel tank... Ect... But when you have one of these in the belt people look right past the defects...
Old 03-20-2005, 03:38 PM
Mark Thompson's Avatar
Mark Thompson Mark Thompson is offline
Images: 75
The Rumely 14-28 and 16-30 are both designated Model H. The 14-28 has ignitors and the 16-30 has spark plugs.
As Ken said, many 14-28's were apparently converted in the field to spark plugged tractors.
The are many factory transition spark plugged 16-30's with 14-28 parts on them. The only difference being the plugs.
Many early production 16-30's had the 14-28 square fuel tank, center shift transmission, 14-28 bull gears, wider drive wheels, flywheel without starting handle dogs and so on.
I have a friend with a factory tagged 16-30 that is identical to a 14-28 less ignitors.
The single cylinder 15-30 and later re-rated 18-35 are designated F.
I hope this helps.
-Mark Thompson
valve guide clearance question & steam engine question Sky Antique Gas Engine Discussion 3 06-07-2005 11:50 PM
[IMG] code is Off
