stuck brass piston on virticle water pump
this thread has 2 replies and has been viewed 1846 times
Old 03-21-2005, 02:59:10 PM
Wayne Weir Wayne Weir is offline
Unhappy stuck brass piston on virticle water pump
I have a gould 3 piston water pump in which the brass pistons are seized. They slide over a sleeve which creates the suction and pressure depending upon the stroke. Can any one help with a method of freeing these. Please! thank you, wayne
Old 03-22-2005, 11:34:40 AM
Email NOT Working
Default Re: stuck brass piston on virticle water pump
Wayne, If it were mine the only thing I could think of would be electrolysis and heat. The electrolysis won't hurt the brass from what I've heard, but it should remove any rust from the cast. Then you could put it in an oven to evenly heat it and then spray if full of your favorite PB Blaster. A few cycles of that ought to get some lubrication to those pistons. I've not seen one, so I assume it's a compact, tight fit on your pump. Vibration would help too. Maybe you could wrap it in a thick layer of inner tube and then give it a good vibrating with a muffler gun. (impact chisel/hammer) They make big, blunt hammer tips to use in them. Take your time, you'll get it. Kevin
Old 03-22-2005, 12:28:22 PM
Patrick McNallen Patrick McNallen is offline
If you can get all the oil off of it, soaking in 10% pickling vinegar as a first step might help free it. Oil will protect the rust from the vinegar.
Stuck piston Dennis K. Nash Antique Gas Engine Discussion 25 02-17-2007 07:18:43 PM
6 hp IHC M stuck piston Chad Antique Gas Engine Discussion 18 07-30-2005 02:23:18 PM
Help! Stuck Piston Vic Pankoski Antique Engine Archives 5 10-05-2002 03:01:53 PM
stuck piston no more Joey Antique Engine Archives 0 08-02-2002 04:59:54 PM
stuck piston Aime Antique Engine Archives 3 05-23-2000 11:52:24 PM
