OT-Lathe Tailstock Chuck
this thread has 5 replies and has been viewed 2796 times
Old 03-25-2005, 12:38:27 PM
Default OT-Lathe Tailstock Chuck
I found this Tailstock Chuck and the owner and I would like some info on it and the company.
Stamped into the body---J.H. Westcott's Little Giant. Double Grip. Westscott Chuck Company, Oneida, NY. USA. Stamped on the face of the chuck, #1. Other #s stamped on the face---133. 20A14.
The chuck has an MT-3 taper.
Width of opening is 13/16". This tells me it would be a 3/4" chuck.
Any info available ?????????
Thanks,
Jim
Old 03-25-2005, 06:42:54 PM
PaulGray's Avatar
PaulGray PaulGray is offline
Images: 38
Lightbulb Re: OT-Lathe Tailstock Chuck
Jim-- That chuck looks a lot like a tap chuck to me. You put a square end tap in there and it keeps it centered relative to the lathe axis. I have seen others which are 3-jaw. They sure are handy for holding large pieces. Personally though, I use a center and a tap wrench and tap by hand.
Old 03-25-2005, 08:00:58 PM
Randy Hart's Avatar
Randy Hart Randy Hart is offline
Images: 2
Default Re: OT-Lathe Tailstock Chuck
Jim, I vote Tap chuck.
I was thinking about it some more and a square drive reamer chuck also fits into the picture,mabey more so than for taps.. this would allow you to drive it in the tailstock on the lathe while spinning the work in the lathe chuck..
Randy Hart Ohio
Last edited by Randy Hart; 03-26-2005 at 09:38:44 AM. Reason: another thought/ I can only handle one per day:)
Old 03-25-2005, 08:34:44 PM
Harvey Teal Harvey Teal is offline
Westcott chucks were the premiere tool chuck before the invention of the Jacobs chuck. Many fine machine tools used them, and they are still as viable as any other chuck.
Old 03-26-2005, 11:05:35 AM
This chuck works very well.
As to the tap and reamer ideas, well I had to take the jaws out and look at them. The jaw teeth are milled at 50 degrees. Not 90. This tells me it would be used for round stock and not for square sholdered material. If square stock was inserted, the pressure points would be on the bottom V of the teeth and none on the other 2 sides.
I may be wrong on this, BUT.
Thanks for your input,
Jim
Old 03-31-2005, 11:38:33 AM
Jim
Well, we are all correct on this. The chuck can be used for round stock up to 3/4" and taps and reamers with the squared end.
An old machinist friend (87 ys. old) looked at it and has used them in the past. There are 2 set screws in the throat bottom that lock against the flats on the tap or reamer ends. He said this is to ensure the tool does not rotate in the chuck. He also said they are as good if not better than the Jacobs Chuck.
Thanks for everyone's info.
Jim
Chuck Woycke KyleBlankenship Antique Gas Engine Discussion 2 12-27-2007 09:57:35 PM
Chuck Wendel JKWidener Antique Gas Engine Discussion 1 12-25-2006 10:59:04 AM
Chuck Sindelar in Wis. dusty Steam Stationary Engines, Traction Engines, Steam Boats 0 03-24-2004 12:37:55 PM
For Chuck Ostrander Chris Kirk Antique Engine Archives 0 02-15-2004 10:25:55 PM
Chuck Wendell Craig Antique Engine Archives 0 05-13-2002 06:56:08 PM
