show trailer ? advice
i just got a 16 foot trailer with wood planks on it , need advice on how to hold engines down ,...
this thread has 5 replies and has been viewed 1751 times
Old 03-27-2005, 12:09 AM
Brickman Brickman is offline
Default show trailer ? advice
hold engines down , mine all have carts on them except one .
i plan on about 8 engines on it ,ranging in size form ihc la 2 1/2 hp to a
6 hp ihc m, ct2 stover,fm z3 hp,fm z d, 4 hp cushman binder, ihc 1 1/2 m
2 hp witte , 2 maytags.
i have the planks bolted down with 3/8 carrige bolts 4 per plank
thanks for any and all advice . ron brown in central il.
Old 03-27-2005, 01:15 AM
Kevin Lemmon's Avatar
Kevin Lemmon Kevin Lemmon is offline
Default Re: show trailer ? advice
When My Dad And I Do That,we Put Wheel Chocks Under The Wheels.they Are Made For Each Engine. We Took A 1x2x However Wide The Wheels Are,then Spaced The Wheels Up With A Thick Washer,put The 1x2 Up Against The Wheel And Then Put 2 Cross Pieces In Between.we Have Used These For Years. To Hold The Engine Down We Either Use 4 Small Chains And Turn Buckles Or We Have Run U-bolts Around The Axle And Thru The Floor.hope This Helps
Old 03-30-2005, 10:10 PM
thanks kevin i like the turnbuckel ideal and the u clamps through floor
Old 03-30-2005, 10:58 PM
RHudson RHudson is offline
how about a hardwood spanner slightly longer than the width of the outside track of the wheels. place the spanner between the spokes of the wheels and run two bolts down through the spanner, throught the floorboards of the trailor, clamping the wheel rim to the trailor. one for the front axle, one for the rear.
Old 03-30-2005, 11:50 PM
Paul Hokanson's Avatar
Paul Hokanson Paul Hokanson is offline
I use the spanner idea on mine but I use 1 inch square steel tubing and haven't had any problems at all. They sit there just as nice as can be. Cheers Paul Hokanson
Old 03-31-2005, 12:33 AM
Exclamation Re: show trailer ? advice
A friend used trailer axle 'U' bolts, to anchor the wheels to the trailer deck. As these are square bent, they don't distort thr rims of the wheels.
How do you show YOUR engines? (on or off the trailer) David M. Lyon Antique Gas Engine Discussion 41 10-04-2009 07:38 PM
Fairbanks Morse 3 hp is ready for the spring show trailer. JimS Antique Gas Engine Discussion 1 10-20-2007 01:40 AM
Engine Direction on Show Trailer Jim Gorter Oil Field Engines 20 09-27-2006 07:32 PM
Engine powered lathe on show trailer ? JKKD Antique Gas Engine Discussion 6 03-03-2006 09:23 PM
Show Truck and Trailer Mike in NC Trucks, Trailers and Hauling for Shows 6 01-20-2006 01:11 PM
