Water Drain Replacment Thread
this thread has 8 replies and has been viewed 1739 times
Old 03-28-2005, 12:53:21 PM
Peter Fletcher
Default Water Drain Replacment Thread
I am working on a ihc IB engine and find the 1/2" (?)pipe thread for the water drain is rusted out, no thread left. Is the right size !/2" and how to renew?
Can any help me with the torque for the head bolts? This isn't mentioned in any Litt. I have. thanks
Old 03-28-2005, 09:37:56 PM
Chip Watford Chip Watford is offline
Default Re: Water Drain Replacment Thread
Peter,There are a couple of fixes that come to my mind.Go to a good auto parts store and get a Heli-Coil thread repair kit.These are available in MANY sizes including 1/2"NPT.You might also run a tap through the hole,clean out all the rust and epoxy a 1/2"by3/8" bushing in the hole and use a 3/8 plug for the drain.My 2 cents worth,Chip
Old 03-29-2005, 11:13:19 AM
OR----
Drill and tap the hole for 3/4" pipe. Go to the plumbing store and get a 3/4" to 1/2" reducer bushing and screw it in. Now you are back to 1/2" pipe. If the hole is 3/8" do the same and get a 1/2" to 3/8" reducer.
Jim
Old 03-29-2005, 07:19:28 PM
Email NOT Working
Either would work well. I'd choose the helicoil as it would require removal of almost no material, and you'll never be able to see it when it's done.
Another thing you could do is just put a little RTV silicone on the plug you have and shove it in. It will set up quick and never come out until you want it to. THat wouldn't be as nice, but cheap and quick. Kevin
Old 03-29-2005, 07:38:51 PM
Why not do what the old timers would do? Just whittle out a wooden plug to fit, tap it in and add water. the wetter the plug gets the tighter the fit. Joe Morris
Old 03-30-2005, 12:47:44 AM
Images: 4
Peter,
The pipe plug is tapered and usually seats tight about 1/2 way in. Try using a
NPT tap to cut new threads deeper, then run the plug in deeper. Caution if you put your little finger into the hole and find that the cylinder or some other obstruction is in the way you might have to grind off the end of your tap and pipe plug to get clearance to tighten it. If the new threads aren't very deep you might have to use some silicone or Peratex sealer or something to get a good seal.
I don't remember the drain plug situation on a LB engine so I can't say for sure that this is the best solution, but it might be the easiest.
As for the head bolts, in the old days most mechanics didn't know what a torque wrench was.
I just Clean up the threads with tap and die to where they thread with the fingers easily for the full usable thread then I use a good grease and tighten them down as tight as feels good. You have to develop a feel for how tight.
Unfortunatly you develop that feel by experience usually the bad kind. Be carefull not to over tighten them.
Maybe someone actually has torque settings for this engine.
Then after you have run the engine and gotten it hot you should retighten the head bolts at least 1 time because the heat will normalize the bolts and gasket enough that it could develope a leak later.
Dick
Old 03-30-2005, 01:19:30 AM
Email NOT Working
Lug nuts on disc brakes are like 80 pounds. I would imagine 40 to 60 would be about right, but you can find general torque specs based on the bolt size in any Chilton's manual I believe. Kevin
Old 03-30-2005, 01:32:19 AM
Jim Sherman's Avatar
Images: 84
Cool Re: Water Drain Replacment Thread
Try this link for torque specifications: torque guide
Old 03-30-2005, 11:07:07 AM
Elden DuRand's Avatar
Images: 6
Jim:
Thanks for the link to bolt torques. I just printed it out and it's goin' on the shop wall. No more rooting through the old engineering books for the numbers.
Take care - Elden
http://home.cybertron.com/~edurand
Atlantic - Drain or no drain? Jeff Miley Antique Marine Engines and Outboard Motors 3 12-15-2007 09:47:27 PM
Difference between Thread Restorer....Rethreader...and Thread Chaser??? packrat56 Antique Gas Engine Discussion 12 07-31-2007 12:59:11 PM
Water gauge on Wachs Cylinder Drain(s) Rick Strobel Steam Stationary Engines, Traction Engines, Steam Boats 9 03-05-2006 07:42:56 PM
Replacment Condensor for AB-33 Bill Blackburn Magnetos, Ignition Coils and Spark Plugs 2 07-08-2003 12:23:25 PM
Water Temp Thread Marty Antique Engine Archives 1 03-11-2003 10:24:10 PM
