Looking for 60s vintage Briggs Coil
I am looking for the coil/magnet assembly for a 7HP Horizontal shaft briggs engine on an economy...
this thread has 6 replies and has been viewed 918 times
Old 03-31-2005, 11:35 AM
CJ Winslow
Default Looking for 60s vintage Briggs Coil
I am looking for the coil/magnet assembly for a 7HP Horizontal shaft briggs engine on an economy power king tractor. This has the horseshoe shaped magnet that wraps around the rotating generator that is about 6" diameter. I was wondering if anybody out there has a source for a new one of these. The local dealers are not that great at looking up older parts. Any help on this is great. I can upload pictures if need be.
- CJ
Old 03-31-2005, 12:30 PM
Mike S's Avatar
Mike S Mike S is offline
Default Re: Looking for 60s vintage Briggs Coil
What engine is that? You could just use a battery and automotive type coil with the original points.
Old 03-31-2005, 02:10 PM
CJ Winslow
I have been running on an automotive coil for about 4 yeats. I would like to go back to the stock setup.
- CJ
Old 03-31-2005, 03:30 PM
Neale Behm's Avatar
Neale Behm Neale Behm is offline
Images: 2
If you can locate the model number of the engine I'll be happy to look up the part number of the coil
Thanks Harry
Old 04-01-2005, 02:22 AM
BWegher BWegher is offline
Thats the "Magnematic" ignition armature. They all used the same coil winding part number. These were common and still available from Briggs a couple years ago, but last I checked they are not listed. Look for an older outdoor equipment shop, may still have one on the shelf.
Old 04-28-2005, 11:23 AM
K D Redd K D Redd is offline
If this engine uses the Magmatic coil P/N 290880, I have found you can modify a later model B&S point type coil and use on these engines. The coil is the later model 2-legged coil which mounts external to the flywheel. I know this may sound a bit goofy as someone said when I approched them about this mod. but he could not believe how easy the mod. was or how well the engine ran after the modification. This modification can be used on B&S models 9,14,19, 23, 1914XX and 2314XX. If ANYONE is interested in this mod send me you E-Mail or snail mail address and I will provide instructions with pictures at no charge. The guy who thought the mod was a bit goofy at first wrote an artical for the GAS Engine Magizine so look for the future artical.
I use this on all my number series engine that the mod. applies to.
Kent
Old 04-28-2005, 02:33 PM
Harvey Teal Harvey Teal is offline
CJ, you can order Briggs parts from Grassland Irrigation on rt7 in Latham, about a mile West of the traffic circle. Biggest dealer in this area.....
Vintage Briggs Model 14 FB dkirk Small Air Cooled Gasoline Engines 7 02-12-2008 08:27 AM
Vintage Briggs HP Question Trashman Small Air Cooled Gasoline Engines 5 11-07-2007 10:48 AM
vintage 6 volt coil Sky Antique Gas Engine Discussion 14 04-30-2007 10:06 PM
Has Anyone Ever Wound a Briggs FH Coil??? JBoogie Magnetos, Ignition Coils and Spark Plugs 2 07-09-2006 03:33 PM
Briggs Coil George Vaughan Magnetos, Ignition Coils and Spark Plugs 3 04-02-2006 09:11 AM
