Stuck piston
I have a verticle water pump, 3 piston, brass, they are stuck anyone have some ideas hot to get...
this thread has 7 replies and has been viewed 1173 times
Old 04-01-2005, 10:40 AM
Wayne Weir Wayne Weir is offline
Default Stuck piston
I have a verticle water pump, 3 piston, brass, they are stuck anyone have some ideas hot to get them unstuck? thank you!
Old 04-01-2005, 11:21 AM
gearedsteam's Avatar
gearedsteam gearedsteam is offline
Images: 2
Thumbs up Re: stuck piston
Try putting a few ounces of Marvel Mystery Oil on them from the top side .. If possible.. move the head from side to side to get good coverage... wait a few days and give it a try.
If that doesn't work... attack with the same MMO from the bottom side of the cylinder... heard this works too.
MMO saved me from a similar fate. I'm a beleiver.
Good luck...
Dave
Eat, Sleep, Do Engines
http://www.gearedsteam.com/
Old 04-01-2005, 11:53 AM
Default Re: stuck piston
If THAT fails--BRAKE FLUID!!! Great stuff!!!!
Old 04-06-2005, 02:17 AM
Clattermac Clattermac is offline
Talking Re: stuck piston
Use coca-cola, it has a pH of like 3.3, very acidic. We used coca-cola out right out of the vending machine in a shop class to get stuck pistons out of a chev 350. Thanks!
Old 04-06-2005, 11:43 AM
Unregistered
Ok fellows. after you have tried every thing, go to the drug store and invest in OIL of Wintergreen. soak the cyl. in that and play with it for movement after a soak period and if any thing will break them loose that should do it.. works for me. Paul
Old 03-07-2008, 12:15 PM
shasis shasis is offline
Only Product on the market specifically formulated to un-seize pistons is called Engine Release.
Comes with good instructions and interesting tips on how to get your engine running.
It's guaranteed too
Old 03-07-2008, 03:04 PM
stephen girouard stephen girouard is offline
Default Re: Stuck piston
marvel oil as mentioned, for a couple of days, if the heads off ,slow and evenly heat the top the piston to about 200 degrees then let it cool , do this 2 or 3 times you'll be surprised, i wouldn't try to turn it until youv did this you might scratch a good cylinder
Old 03-07-2008, 03:10 PM
another machanic here says aero kroil is as good as marvel oil also
Stuck piston help BobM Antique Gas Engine Discussion 25 02-22-2008 11:15 PM
6 hp IHC M stuck piston Chad Antique Gas Engine Discussion 18 07-30-2005 03:23 PM
stuck piston no more Joey Antique Engine Archives 0 08-02-2002 05:59 PM
stuck piston Joey Antique Engine Archives 16 08-01-2002 11:27 PM
stuck piston Aime Antique Engine Archives 3 05-24-2000 12:52 AM
[IMG] code is Off
