Jacobsen 10-Acre reassembly
this thread has 1 replies and has been viewed 1345 times
Old 04-02-2005, 02:43:03 PM
Default Jacobsen 10-Acre reassembly
Soon I'll be ready to put the piston back in my Jacobsen 10-Acre engine. From the looks of the "expanded" top of the cylinder and the bevel on the crankcase end of the cylinder I assume the piston goes in from the bottom. Is this correct?
I marked the crank gear and the cam gear before I took the crank out so I think I'll have the engine timed when I reassemble, probably won't make much difference for a while since I don't have a mag and haven't gotten the carb cleaned and freed up yet.
Old 04-03-2005, 10:09:07 AM
Elden DuRand's Avatar
Images: 6
Default Re: Jacobsen 10-Acre reassembly
On some engines, you could put the piston in from either end of the cylinder. I think the bevel at the bottom is to help you if you want to pull the piston without removing the head.
On some other engines, the top of the cylinder (above the piston travel) like the F-M Type T (Jack of All Trades) wasn't machined and you had no choice but to put the piston in from the lower end of the cylinder.
Take care - Elden
Jacobsen 4 Acre Mower Tilinghast Antique Gas Engine Discussion 13 04-19-2010 11:03:26 AM
Jacosen 23" and 30" 4 Acre Mower. Tilinghast Antique Gas Engine Discussion 5 02-19-2009 03:36:31 PM
Jacobsen Four Acre mower engine Manuel Azevedo Small Air Cooled Gasoline Engines 7 06-12-2008 05:50:12 PM
An Acre An Hour 1917 Huber "LIGHT FOUR" Dick Graybill Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 09-01-2005 04:13:23 PM
Jacobsen 10-acre engine question Leonard Keifer Antique Engine Archives 0 04-29-2004 06:38:27 AM
