Pondering Propane
this thread has 4 replies and has been viewed 1110 times
Old 04-04-2005, 02:41:03 PM
Mike Inglis's Avatar
Mike Inglis Mike Inglis is offline
Question Pondering Propane
I am thinking of running my 3 HP Deere on propane, my plan is to use a 10lb tank with regulator running into an IMPCO fuel lockoff into a modified mixer.
Im just wondering how i should meter the fuel at the mixer or if i even have to if i choke it off enough at the tank.
The filter lockoff requires 0.5" hg to operate.
Any thoughts or advice would be great....as im just doing this as a challenge
Mike
Old 04-04-2005, 04:18:28 PM
Andre Blanchard's Avatar
Andre Blanchard Andre Blanchard is offline
Default Re: Pondering Propane
Here is a google search.
http://www.google.com/search?q=propa...utf-8&oe=utf-8
You need a demand regulator. You could likely get by without one but at an increased chance of finding out what a fire ball looks like from the inside.
_______________
Andre' B. Clear Lake, Wi.
Old 04-04-2005, 04:41:04 PM
BobRR BobRR is offline
Mike check the archives as there was some discussion on this a while back. Im with Andre you should use a on demand regulator! BobRR
http://www.smokstak.com/forum/showthread.php?t=17395
Old 04-04-2005, 06:35:24 PM
The lockoff i have is a vacuum lockoff which allows flow only when a vacuum signal is sensed
Im just wondering if i should regulate with a needle valve
Thanks again
Mike
Old 04-04-2005, 07:50:40 PM
Justin Justin is offline
Smile Re: Pondering Propane
I would reccommend running with a needle valve because you can run the engine slower. I have a regulator and then a 3/8" shut off on my FB ZD and the slowest I can get that to go is about 150 rpms on the crank shaft because that is the least amout of fule the shut off will allow through.
Justin Eckel
Pondering a Boiler Vintage Camaro Steam Stationary Engines, Traction Engines, Steam Boats 39 03-28-2008 05:15:36 PM
LP to Propane Ace59 Generators & Motors General Discussion 13 08-02-2007 07:56:04 PM
FM Z on propane John Stewart Antique Engine Archives 1 02-13-2002 08:01:25 PM
PROPANE Randy Peterson Antique Engine Archives 4 01-05-2002 09:20:35 PM
