Tobyhanna army generator Mdl. 701A 3KW
this thread has 15 replies and has been viewed 9449 times
Old 04-04-2005, 09:13:52 PM
Doogdoog Doogdoog is offline
Default Tobyhanna army generator Mdl. 701A 3KW
Aloha,
I just came across a Tobyhanna army generator mdl. # 701A 3Kw diesel generator with the sound enclosure and would like to know where I may get a manual for the engine and generator and also parts. I don't know who made the engine and it isn't running yet . All suggestions and replies will be greatly appreciated. TIA
Mahalo,
doogdoog
Old 04-05-2005, 06:01:47 AM
Default Re: Tobyhanna army generator Mdl. 701A 3KW
Aloha,
I forgot to add the following:
MEP 701A
TM 5-6116-12/24p/34
NSN 6115-01-234-5966
NSN 6115-01-150-4140
I am also looking for a wiring diagram. TIA
Mahalo,
doogdoog
Old 04-07-2005, 09:54:19 PM
Jon Gibson Jon Gibson is offline
Question Re: Tobyhanna army generator Mdl. 701A 3KW
Check out https://secure.tpub-products.com/tpu...27f1ef31f17621
I downloaded .pdf versions of the manuals for my MEP-015A for a mere $3 each. Hard to beat the price...
Old 04-08-2005, 02:21:39 AM
Aloha Jon,
Thanks for the link but I couldn't find my model. TIA
Mahalo,
doogdoog
Old 04-08-2005, 04:09:50 AM
Default "UPDATE" Tobyhanna army generator Mdl. 701A 3KW
Aloha,
I removed the top sound supressor cover and there was another ID plate mounted on the top of the control panel and I will try to post a picture of it. It is strange that they would have two different ID plates and I found out that the engine is a Onan diesel. I will try to look for any identifying numbers for the engine. TIA
Mahalo,
doogdoog
Old 04-08-2005, 09:26:33 AM
K D Redd K D Redd is offline
The "TM" numbers on you data plate are the Training Manuel numbers.
Kent
Old 04-08-2005, 01:46:51 PM
Unregistered
What you have is a Model Number MEP-016B. That number will be the key reference number when researching this item.
3 kW Diesel generator. Manuals for all the MEP (Mobile Electric Power) generators are available on CD at Ebay.
Old 04-08-2005, 03:21:30 PM
Aloha,
Thanks for all the help and does the CD on ebay have the wiring diagram on it too, or is it just for the engine or both? TIA
Mahalo,
doogdoog
Old 04-09-2005, 05:05:19 AM
Aloha,
Does anyone know where I can get a fuel filter element and also the element for the air filter? TIA
Mahalo,
doogdoog
Old 06-08-2011, 02:50:58 PM
fredster67a fredster67a is offline
This link ought to take you there ( site for a manual)
http://igor.chudov.com/manuals/Other...16B/062759.PDF
The Following User Says Thank You to fredster67a For This Post:
Old 06-20-2011, 06:14:57 AM
Aloha fredster67a,
Thanks for the link and it sure hits the spot.
Mahalo,
doogdoog
Old 07-06-2011, 09:55:25 AM
seo seo is offline
Hi, I also have one of these generators, which I recently bought from Gov Liquidation. It was a package deal, two generators and a trailer, described as follows:
"2 each Mdl MEP-701A 3 KW diesel engine generator sets with suppression kits, Mfr unknown, Sn's T-90-135-ASK-0498 & T-90-135-ASK-0500, meters indicate 152 & 222 hours, 120/208 V 3 phase, 120/ V 3 phase, 240 V 1 phase, 120 V 1 phase, operating condition unknown, Mounted on Kasel Mfr Co Mdl M116A2 2 wheel 3/4 Ton cargo trailer chassis."
So far I've gotten one of the generators running, it starts like a charm and runs well.
The manual that I've found on line seems complete, but I haven't yet found the part that deals with switch settings, and how to wire a panel for it. There are all the controls on the individual generators, plus a separate panel with a selector switch marked gen 1, gen 2, and also seems to have a click in the switch that's not marked. Could this be "both?" If so, then I could use the paired generators to power my welder on the lower half of the welder power settings. That would be fine for welding with 1/8" 6011 rod, which is what I mainly use.
Does anyone have experience using these to power a Lincoln 225 AC "buzzbox?" It seems that military gear is often able to work above rated capacity.
My final questions are about the "convenience receptacle," the pair of 110v plugs on the panel front. So far, that's all I've been using, and have blown a couple of the 15 amp buss fuses using my Skil worm-drive saw.
Does anyone know if this "convenience receptacle" is hooked up to L1, L2.
So far, I'm only getting 104 volts at the receptacle, and the cycle counter is pegged at 68 Hz. The voltage control doesn't seem to have any effect on the voltage either on the panel gauge or measured at the receptacle. Bad rheostat?
I think that I've figured out that the "throttle" control is just for idling down, and that full governed RPM is used when actually generating, and that the governor has to be adjusted to get the correct cycles. I spent some time trying to make it work like the 60kw Detroit/Delco generators that I'm familiar with, where there's a hand-wheel that adjusts the governor to get the correct cycle count.
I'd appreciate any comments or advice.
By the way, Govliq has two of the 3kw units up for auction at Concord, NH,
http://www.govliquidation.com/auctio...&convertTo=USD
Auction closing on 7/7/11 at 5pm EDT
Old 07-06-2011, 10:36:28 AM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Tobyhanna army generator Mdl. 701A 3KW
That switch is certainly NOT. a "Both" Switch.......
Bruce in alaska
Old 07-06-2011, 09:53:34 PM
seo seo is offline
So, are you saying that the two won't run together against a common load?
Old 07-06-2011, 10:55:12 PM
Jim McIntyre's Avatar
That's correct.
Old 07-07-2011, 12:20:03 PM
BTPost's Avatar
Images: 1
and IF you try to do that, EXPECT to see the Magic Smoke leak from one OR both you Gensets....
Bruce in alaska
Army Generator Tom Rowe Generators & Motors General Discussion 6 03-02-2011 01:13:08 AM
Onan army generator 6JB 53E ? elfinwood Onan Generators 6 05-10-2007 08:21:43 PM
army generator parts Russell Daves Generators & Motors General Discussion 1 08-15-2004 07:07:37 PM
Generator, MEP 701A, 3KW, Diesel Rb Hawaii Military MEP and Aircraft Gen-Sets 2 01-05-2004 11:02:44 PM
1941 Army generator Calvin C. Generators & Motors General Discussion 0 09-08-2003 04:07:29 AM
