Galloway info wanted
this thread has 2 replies and has been viewed 1206 times
Old 04-05-2005, 08:36:48 AM
Dale S Dale S is offline
Question Galloway info wanted
Just bought an original Galloway cart from Steve Oswald, He's a great guy with a fine collection. Does anyone have a picture of the wood tongue assembly.I need to build one. Also does anyone know how the gas tank mounts to the cart.I have read something about four bolts, but I don't know how it gets fastened down.
Old 04-05-2005, 09:32:02 AM
Rick Strobel's Avatar
Rick Strobel Rick Strobel is offline
Images: 20
Default Re: Galloway info wanted
Dale is this cart for the bigger engines ie 5hp, 7 and 9(?). Do you have a picture especially where the pipe axle(s) attachs to the I beam(s)? If not, explain to me how they are held together i.e. U-bolts or two bolts with strap metal.
I have two carts/trucks with the sawing attachment and they're different.
See my older style with roundrod @
http://community.webshots.com/album/88886243mzpsZq
There's pictures there of the tank also, but don't believe I used the correct mounting as there appears to be evidence of a band halfway down on the tank.
Hope this helps alittle
RickinMt.
Old 04-08-2005, 02:05:03 AM
Exclamation Re: Galloway info wanted
Dale,
My 5 HP Galloway fuel tank had 4 flat lugs soldered to the base of the tank. They are about 1" wide, about 3" long and 1/8" thick. About 1 1/4" of the lug extends beyond the edge of the tank, and there is a 1/2" hole drilled thru the exposed part. The hole is 1/4" from the outside edge. Outside of the lug is rounded. Tank is mounted to cart, level with engine base, with 4 - 3/8x1 1/2 square head lag bolts
Info Wanted James Smitherman Antique Engine Archives 2 03-10-2004 08:36:29 AM
Galloway info needed d.j.baisch Antique Engine Archives 3 12-21-2002 01:28:18 AM
Galloway Info Pollack Pete Antique Engine Archives 2 06-29-2001 10:39:32 AM
Galloway 12 hp info Huck Morgan Antique Engine Archives 10 05-22-2001 09:09:38 PM
GALLOWAY INFO NEEDED BUCK ANTHONY Antique Engine Archives 1 06-12-2000 09:14:12 PM
