Can't get it started
this thread has 2 replies and has been viewed 1935 times
Old 04-12-2005, 09:53:38 PM
ShawnStacy ShawnStacy is offline
Question Can't get it started
Just got my magneto back from being rebuilt for my aermotor, but I cant get it to start. I got it to POP a few times but it just wont go. Was wondering where would be a good place to start on the air/fuel mixture. After checking everything else, that is all that I can think of thats left. Im very new to this as this is the first hit & miss engine i've ever played with. Any help would be apprieciated. Thanks, Shawn
Old 04-12-2005, 11:42:42 PM
Chuck Parcher (Ks.) Chuck Parcher (Ks.) is offline
Default Re: Can't get it started
Check your compression If it has SPARK, FUEL, and COMPRESSION, it has to run.............SPARK...Check timing.
CHUCK
Old 04-13-2005, 12:10:20 AM
Images: 17
Shawn: I bet its the screw adjustment found between the magneto and bracket that actually causes the igniter to trip. It should be real close, but not quite touching the movable electrode. A turn or two in/out just might solve the problem. . Also make sure the magneto trips at the right point (usually just a bit before top dead center on the compression stroke) by adjusting the trip push rod. Usually doesn't take much.
Did you make a new friend today, and a lot. Paul - "OLDIHC"
getting a jr club started john s Antique Gas Engine Discussion 7 02-11-2007 02:37:36 AM
I can't get the Cushman started Mike Schweikert Antique Gas Engine Discussion 7 09-04-2006 06:43:52 PM
It started!!!! Will Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-19-2006 01:34:38 AM
Getting started... New guy Aaron Rogahn Antique Engine Archives 8 03-15-2002 10:13:34 AM
Want to get started Hal Davis Antique Engine Archives 10 07-29-2001 12:09:58 PM
