INTL. LB oiler wick
this thread has 6 replies and has been viewed 1553 times
Old 04-14-2005, 11:51:43 PM
Chuck Parcher (Ks.) Chuck Parcher (Ks.) is offline
Default INTL. LB oiler wick
On the Intl. LB engines the oiler tube that comes out of the block between the push rods, has a wick inside it. What kind of wick is it? It looks like two twisted up candle wicks. No suppliers on this site seem to have them, what can be used to replace them that will supply the oil to the trough?
Thanks.........CHUCK
Old 04-15-2005, 12:22:45 AM
Email NOT Working
Default Re: INTL. LB oiler wick
Chuck, I just used a piece of heavy felt on mine. I suppose that even one of those green scrubby things from the kitchen would work fine. I think foam rubber would even work but deteriorate quickly. In a pinch, a piece of rope untwisted and laid in there would probably work also. I guess it would depend on if you have a valve cover or not to cover it up, and how ugly you can stand! I would go with some felt. You might find some heavy felt in a gasket set, fabric store, craft shop, or buy a hat at Goodwill or Salvation Army and cut it up. Enjoy, Kevin
Old 04-15-2005, 07:52:23 AM
Unregistered
Chuck: cotton Mop String Works Very Well For This.
Jerry
Old 04-15-2005, 02:09:22 PM
Meco3hp Meco3hp is offline
Images: 62
Hello,
Kevin, I think Chuck is refering to the tube that carries oil out to the oiler trough. It also has a wick in it. This is one of the things I replace any time I work on these engines. I also check to make sure that it in fact has one. If and when you replace one of these, you should "oil" it before you reinstall it. After I install the wick, I always push the wick (cotton mop string) about 1/2" inside the tube. Then holding it with that end up I pour oil into it until oil runs out the dripper end.
Also make sure that the little trough in the crankcase that catches oil for this tube is also cleaned out.
Chuck, I'd get a old style cotton mop from the store and use a string or two from that. Be sure to test a little bit of the cotton string to make sure it would soak up oil. I had one one time that refused to oil. I finally decided that the string wasn't soaking the oil up and wicking it through the tube. I double checked a small peice of the string and it wouldn't soak up the oil. Don't ask how I know this. We'll just say I messed up a really nice new paint job figuring this all out.
See ya!
Richard
Old 04-16-2005, 09:31:47 PM
GarysToys GarysToys is offline
A while back someone said to use a felt balckboadr eraser for the felt in the trough.
I did and it works great.
One eraser gives you enough for years of replacements, that is, if you remember where you out it.
Old 04-16-2005, 09:42:32 PM
Dave Hyatt Dave Hyatt is offline
Inside the tube is a 'wick' which basically keeps the oil from running out too fast through the metering needle and into the tough above the rockers. Cotton string from a mop is a good suggestion. I bought a pair of white cotton shoe laces, folded them in half and twisted them the same amount of turns as the old wick I pulled out. That worked perfect on mine. If I had it to do over, I would soak them in oil first otherwise you'll be running the engine for about three hours before the splashed oil inside the engine is absorbed enough by the wick to allow any to pass out into the trough. Ed at Hit n Miss has the felts for the trough all cut to size. He doesn't have any wicks, though. You'll have to get creative on your own.
Dave
Old 04-17-2005, 11:41:40 PM
Images: 4
Yea.
A number of years ago I bought a good chalk board eraser from a teacher supply and took my wifes stitch remover and cut the stiches to take it apart and that provided me with about 8 good felt pads for the rocker arm drip troughs. A lifetime supply. The cotton mop string works good for the wicks.
Dick
Valve oiler pipe wick P J Philip Antique Gas Engine Discussion 1 09-06-2007 01:36:46 PM
IHC LB Lubricating 'wick' Dave Hyatt Antique Engine Archives 7 09-20-2004 10:21:49 PM
Mfg dates FM, Intl M, Economy Roger White Antique Engine Archives 3 09-03-2004 03:49:43 PM
!5 HP Reid oiler wick for rod Bob Johnson Antique Engine Archives 1 08-31-2004 08:43:06 PM
Valve oiler pipe wick Jerry Griffin Antique Engine Archives 1 03-14-2002 07:59:46 PM
