sweetened condensed can as mini gas tank?
this thread has 3 replies and has been viewed 1043 times
Old 04-20-2005, 05:16:37 PM
CGBusch CGBusch is offline
Default sweetened condensed can as mini gas tank?
I want to make a mini gas tank and I was thinking that a sweetened condensed can would be the right size, I could solder a cover for it. My question is, will the gas dissolve the food lining glaze? (is there one?) Will leak though the seams due to the potential dissolving action?
Old 04-20-2005, 05:41:55 PM
Email NOT Working
Default Re: sweetened condensed can as mini gas tank?
My answer to both questions is "I don't know". But I doubt that it would leak in any case. Why don't you use some good fuel tank sealer in it, and be done with all potential problems before you ever start? I think the milk can would make a nice tank. Kevin
Old 04-20-2005, 11:17:41 PM
BillsToys BillsToys is offline
From a chemist. The lining will probably dissolve. Hit it with some MEK or Lacquer thinner then the use of the gastank sealer is optional.
Bill O. from Ohio
Old 04-21-2005, 01:55:37 AM
BWegher BWegher is offline
I've successfully used a quart grapejuice can. Also used a glass jar with hole in cap for suction carb on a Fairbanks-Morse.
If you don't need gravity feed, just put a small hole in the top, drop the fuel pick-up tube into the hole and you're done. I cut out quarter sized "hole dust cover" with friction fit hole for the pickup tube and large enough outer diameter to cover the hole in the top of the tank.
Mini Lathe JKWidener Scale Model Engineering 4 11-25-2007 04:54:42 PM
My Mini-Bike TheEngineGal Garden Tractors / Mowers / Scooters 17 03-22-2007 06:05:42 AM
mini jaeger mixer maxx Antique Gas Engine Discussion 1 05-25-2006 11:05:42 AM
Mini Steam Locomotive? Mark Ilg Steam Stationary Engines, Traction Engines, Steam Boats 11 09-03-2002 10:02:48 PM
